how much oil does ths thing take??
Old Mar 14, 2004 | 08:37 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
well the question is stupid but here it goes. a 79 350 as listed below... i need to know what the deal is with this thing. i put a oil pan gasket on it a little while ago with no prob never leaked or nothing ran it probraly 10 - 15 miles since and probraly at least 3 hours of run time,its a good 40$ gasket. well i was running it a little at some high rpms (5k)and all the sudden it started smoking from under the hood. when i opened it and looked i saw what apeared to be oil all over everything on the front of the motor.i looked around to see what the deal was and noticed were it seemed to be coming from the front were the timing cover and the oil pan meet. i used silicone to seal that area as it instructed and im not fully sure that thats were it came from. anyways when i put oil in it last it took 6 quarts of oil to make it apear full on the dip stick.i just installed that as well its a chrome style aftermarket. i made sure that the dipstick tube was pressed all the way into the block when i put 5 qts in it still didnt show up so i put another and it showed level. the dip stick is made for my year and the pan is stock. i didnt want to risk not having enough. ever since it started spraying oil i havent been able make it do it again to see were it came from but i dont wanna risk driving it till i find the problim.. any ideas what might have happened???should i get a new dip and drain some oil or does 6qts seem ok??
Old Mar 14, 2004 | 10:42 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If it's a factory pan for a 79 350, it holds 4 quarts plus the filter.
Old Mar 14, 2004 | 11:21 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
so basicaly its forcing the oil out because it has no place to go.. probraly blew my front crank seal and slung the oil all over the place because it got on the balancer?? rrrrrrr i hope it didnt hurt anything..
Old Mar 15, 2004 | 07:41 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I'm going to assume you yanked off the smog pump.... correct?
So ask me how I know that.
Old Mar 15, 2004 | 11:32 AM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
yup... how did you know that???
Old Mar 15, 2004 | 11:36 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Because your motor leaks oil out the front.
Look at the front of the block. Where the smog pump should be, there are 2 bolt holes. If you look in the upper one, you will see the fuel pump drive rod passage..... in other words, you are looking RIGHT DIRECTLY INTO the crankcase.
Put a short bolt, like ¾" or so, in that hole with some silicone on the threads. That'll keep it from spewing like the Exxon Valdez until you can get the smog pump back on. Then take it to the quarter car wash and clean all the schmutz off of it and see if it stays clean.
Old Mar 15, 2004 | 12:00 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
hahahahah omg thanks rb this is like the tenth time youve saved me from somthing stupid ... come to think of it thats exactly were it looks like it came from.lol i didnt know that the hole would expose my fuel rod.... thanks again i owe you...:hail:
Old Mar 15, 2004 | 01:32 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Alot of things I've learned by watching other people screw up, and absorbing the knowledge; but that is one screw-up that I can personally take credit for! I drove a car around for months that did that. Finally one day I took it to the car wash and sterilized it, and let it sit there and idle, and saw oil oozing from that hole.... I felt like such an idiot. I already knew the trick of using a longer bolt to hold up the fuel pump rod, I just had failed to connect that with the leak; until I saw oil running out. Now I don't forget any more.
Old Mar 15, 2004 | 05:30 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
yea well im glad you knew..... my mechanical pump is no more i have moved to electric and the rod isnt even in there anymore plus it has too much oil in it. so you can imagine the mess..
Old Mar 15, 2004 | 10:09 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Amen... thats were I got everthing I know
xxx3man`
Sep 23, 2015 10:37 PM
Navy8125
Aug 21, 2015 09:32 AM
Bob88GTA
Aug 18, 2015 03:31 PM
86White_T/A305
Aug 17, 2015 12:16 AM
