air pump
Old Mar 15, 2004 | 09:26 AM
DSmith's Avatar
Car: 1989 Camaro
Engine: 383
air pump
Whats the best way to run the belt without the air pump. I'm using the brackets from the old 89 LO3 that came in the car.
The air pump is not hooked up its just mounted so I will have a place to run the belt.
Old Mar 15, 2004 | 11:22 PM
hwcoll95's Avatar
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
there's a article
about it,you use a 967 belt i think,if i can dig the link i'll post it back here?@?
dyeager535
Aug 28, 2015 08:10 AM
Dialed_In
Aug 20, 2015 01:45 PM
mcquigg
Aug 13, 2015 02:26 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
