racing question
Old Feb 19, 2001 | 08:29 PM
v6-3.1's Avatar
racing question
I have camaro automatic 3.1L 1990. I was wondering if it is safe to bring up the rpm in neutral and then shift to either 1st or OD without messing up the tranny or the engine
Old Feb 19, 2001 | 08:33 PM
Josh 91RS's Avatar
No. I would not recommend that at all...What you really want to do is get the car going about 10mph in reverse...then slam it into first... just kiddin, step on the brake and raise the rpm's up. Then let off the brake and hit the gas at the same time. Experiment with the rpms to find whats right for you.
Old Feb 19, 2001 | 08:36 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Not unless you have a lot of money to buy new transmissions.
An automatic tranny is not a standard with a clutch. Doing a neutral drop from a high rpm is the easiest way to destroy an automatic. You might as well jam it in reverse at highway speeds while you're at it. It will have the same effect.
If you want to launch at a higher rpm, buy a higher stall converter.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Feb 19, 2001 | 09:00 PM
Josh 91RS's Avatar
Old Feb 20, 2001 | 01:23 AM
Conv389drv's Avatar
Neutral drops = very bad KABOOM!!!
With the trans in gear, hold the brake with your left foot to keep the car from moving. Give it gas with your right foot to raise the rpms while the car is sitting still (around 1000-1500 I'd guess). When you're ready to launch, release the brake and mash the gas to the floor at the same time. I'm assuming wheel spin won't be a problem, but if so, feather the gas until you hook up, then floor it.
Old Feb 20, 2001 | 02:36 AM
burnoutrpm's Avatar
my frined thought this would be cool also well he learned a good lesson neutral drop = destruction!!! first we changed the tranny mount, then he keep losing fliud, front seal blew out then he lost second gear all thogether!! and it still runs just shifts from first to 3rd no 2nd!!! so that should be a good indicator of what to expect!! no dont just power brake untill you find the break-way point and go just 100rpms under that and release brake and floor it!
1989 firebird formula
Mods: converted from T.B.I. to a carburator 305 to a 350. Flowmater exhaust,hedman shortie hedders,202 160 (882) heads,.447/.447 lift 222@.050 duration speed pro 327/350hp cam 350 .40 over (356) edlebrock performer rpm intake and a 600 edlebrock manual choke (1405) Proform H.O. distributor slightly revised 700r-4
Future mods comp extreme energy roller cam, world products sportsman 2 heads, msd 6al ignition, billet distributor, blaster 2 coil and a 406 engine is in the works soon!!!!
Old Feb 20, 2001 | 03:59 PM
84TransAm's Avatar
My friend who had a 91 Tracer always did this when we raced. Squealed hard off the line (for a POS), but after 6 months it caught up with him, now it wont shift to 2nd.
--Steve S--
1984 Trans Am 305 LG4, 5 speed
Daily Driver, Flowmaster 80 Series
NOW FEATURING: Holley 600 cfm & vacuum advance
Old Feb 20, 2001 | 04:27 PM
ede's Avatar
ede
where's the racing question?
ICON Motorsports
1st & 3rd
Old Feb 20, 2001 | 09:15 PM
mcconahay37's Avatar
A dumb*** at school tried this in his blazer. I'm driving out of the parking lot and all of a sudden I see bolts and pieces of metal blow out from underneath his truck. He revved it up to about 5000 rpm and dropped it into gear. He got it back 2 weeks later and did the exact same thing. Next, his dad to it away from him and he was riding the bus to school.
82 Camaro:
350, Erson cam, ported heads, Crane Hi-6 ignition, Accel supercoil, Comp Cams 1.6:1 rocker arms, Turbo 350 tranny with 2500 stall.
wild1
Aug 27, 2015 09:01 AM
theurge
Aug 21, 2015 12:46 PM
PestilenceIV
Aug 20, 2015 03:32 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
