roller tip rockers
Old Mar 15, 2004 | 09:27 PM
84350camaro's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 355
Transmission: TH350
Axle/Gears: 3.08
roller tip rockers
anybody here use or used roller tip steel rockers? thinking of getting the summitt ones.............
Old Mar 15, 2004 | 09:30 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: roller tip rockers
Lots of people use them with great sucess. You need to consider a few things though. Usualy aftermarket rockers can cause valve cover clearance issues. Also, aluminum ones aren't the best choice for street use since they tend to wear out fast. Last but not least you need to make sure that the new rockers will not push the lift limits past the max lift of your stock heads. That is if you have a cam of course.
Old Mar 16, 2004 | 05:54 AM
ede's Avatar
ede
i've used them, always steel and from comp. i know a lot of people that have used them.
Old Mar 16, 2004 | 11:06 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
I'm about to replace my heads and cam and that's what I am going to put in mine.
Damon's Avatar
Agreed. I've got a cheap set of stamped steel rockers with the roller tip I bought from Summit a while back on my current 383 blower motor. They work just super. I wanted to go with aluminum full roller rockers but they wouldn't easily fit under my valve covers and caused marginal pushrod problems with my AFR aluminum heads. All fixable, of course, but I had the roller tipped ones laying around that didn't cause these issues so I used them.
jrdturbo
Mar 31, 2016 02:58 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Agent507943
Camaros Wanted
Oct 2, 2015 07:17 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
Night rider327
Sep 25, 2015 04:47 AM
