Where is the fuel filter?
Old Feb 21, 2001 | 03:18 PM
Cliff92Z's Avatar
Car: 1992 Z28
I want to change my fuel filter but don't know where it's at. I have a '92 Z28 TPI 305. Can someone help me out? Also, is it difficult and/or time consuming? Thanks.
1992 Z28 (305) TPI.
160' stat, Accel 8mm, Accel Cap & Rotor,
Flowmaster, high-flo cat.
Old Feb 21, 2001 | 03:22 PM
chevyboy07 91's Avatar
It's towards the rear of the car on the driver's side. For some reason I can't picture "exactly" where it is but I wanna use the rear tire for refrence. I think it's a little in front of the rear tire and towards the driver/center of the undercarriage. it's much "funner" when you have a lift b/c when I try to get the new one on there gas always runs down my arm and burns MORE then a bite from satan.
Old Feb 21, 2001 | 03:23 PM
ohh.........and it's basically 2 nuts and less than a half hour including clean up.
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
The fuel filter is located under the car, on the drivers side, back by the rear LCA perch. Should be relatively easy to replace, just make sure you depressurize the system. (or work real quick ) The fittings may be rusted, so use some WD-40 or equivalent to help break loose.
Bob '89 Formula CC350
Last(lost)Member of the Elusive Great Lakes Crew
My car's homepage
Old Feb 21, 2001 | 03:26 PM
Cliff92Z's Avatar
Car: 1992 Z28
ok thanks...i was bout to spend $45 at the shop to get it installed. I should try doing it myself. Doesn't sound like I need any special tools. How do I depressurize the system?
Old Feb 21, 2001 | 03:35 PM
ohh yeah....I guess I should have mentioned it's under the car. oops
Old Feb 21, 2001 | 04:08 PM
86Trans Am's Avatar
when i do mine, all i do is take the gas cap off, wear saftey goggles, and make sure not to twist the fuel lines off when removing the filter. you should only lose a few drops of gas
1986 Trans Am
305 TPI
"If it's not one thing, it's another!"
http://www2.hanover.edu/hierlmeier
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
