Thirdgen differential in an S10?
Car: 4
Engine: 6
Transmission: 5
Yes. They interchange, but with all the same caveats that 3rd gens have within their own family.
ICON Motorsports
ICON Motorsports
Car: yep
Engine: uhuh
Transmission: sure does
I imagine the guts are the same, but the housings are different.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
My favorite quote about D.E. "He can see air"
[This message has been edited by Engineboy (edited February 21, 2001).]
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The width is a little different. I think the third gen is wider. It wouldn't be very hard to mount it. Cut off all the third gen mounting hardware. Take off the leaf spring and shock mounts from the S10 and weld them onto the third gen housing. Just make sure the measurements are correct.
It would be an improvement if you are putting a 9 bolt into the S10. Just as long as the gear selection is what you want it would be a better diff to use.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.662
Car: 4
Engine: 6
Transmission: 5
Right... I should have said, the innards are the same. The housings are totally different. You can swap posi carriers and gears but not axles and housings.
All the S trucks, F cars, and G cars (with a very few specific exceptions) got the 7.5" rear. So did some of the B cars.
ICON Motorsports
ICON Motorsports
<font face="Verdana, Arial" size="2">Originally posted by RB83L69:
</font>
</font>
Car: 82 camaro SC
Later third-gens also got the 7 5/8 gears. They fit in the same housing, just a small increase in size. Later model S10's could be ordered with an 8.5 inch 10 bolt. Like they said above, the carrier/ring/pinion are the same, everything else is different.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
82camaro
Car: 4
Engine: 6
Transmission: 5
That's what I was referring to earlier... that's the same year more or less that the F cars changed axle splines and all that too. It's the same basic piece, which interchanges within all those housings, just minor detail differences. Just enough different that they don't fit together... exactly the same except for being totally different.
ICON Motorsports
ICON Motorsports
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
red90IROCls1
Aug 25, 2015 06:56 AM
