Will these valve springs work?
Old Mar 18, 2004 | 07:44 PM
mhaskell's Avatar
I have a 1992 L-98, teh heads have never been off, pretty much stock. I want to freshen up the top end, will these springs fit the stock head, using stock retainers and keepers? Will the install height work? I just want a stock type spring to bolt on, opinions?
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEBWA:IT
brand new set of 16 Z28 style, high performance valve springs from Precision Racing Components. These springs are a drop-in fit with a stock 1.260" outside diameter and .880" inside diameter and will handle up to .550" cam lift .
Spring Pressure Installed: 110# @ 1.700"
Spring Pressure Open: 325# @ 1.200
Coil bind @ 1.150"
Old Mar 18, 2004 | 07:55 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
They look similar to Comp Cams 981's.
Maybe it's just me, but I'd never buy springs from a guy that can't do simple math.
1.700" - 1.150" = .550" - (at least) .050" to prevent coil bind = .500" lift
If you're not going over that lift, they'll work.
Old Mar 18, 2004 | 08:34 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
This is just me, but for springs, i prefer to stick to Isky, Comp, Crane, Lunati, Crower. The recognized names (recognized by me that is).
But like i said, thats just me.
Old Mar 19, 2004 | 04:48 AM
ede's Avatar
ede
i'd guess the springs are junk. they would fit stock heads, retainers, etc. you're going to be way ahead buying springs from comp, lunati, or crane along with retainers and trashing the factory parts.
customblackbird
Aug 15, 2021 10:16 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
89mulletbird
Aug 12, 2015 07:08 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
