Fuel Pressure Regulator leaking
Old Feb 20, 2001 | 07:54 AM
Dan91Z's Avatar
I put on an accell adjustable fuel pressure regulator and it leaks.. I put it on how the stock one came on it, which dosen't seem right to me. Someone replaced it before, and I'm not to sure they put it on right. I need to basicaly find out how it goes on to the engine.
The way it was before I started was like this. from bottom to top
1. A ring about 1/16" thick with 8 holes with a bead on one of the sides, bead side down.
2. The fuel pressure diagphram
3. Housing
and when I installed the accell one
1. The same ring facing the same way stated above.
3. Something that looks like a quater
4. Adjustable housing
I used the bottom ring thing from the stock one with the accel one cause the accell one didn't come with one, and the stock one didn't have the diagphram touching the metal mounting thing.
It also seems weird that the bead on the ring thing would be facing down instead of up. I'll try to get some pictures up in a little to try to explain better
Old Feb 21, 2001 | 12:33 AM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Here's the order from fuel rail up:
Diaphragm with spring facing up, "quarter" on top of spring, housing with adjusting bolt, ring with lip facing up, not down, bolts.
I'm not clear on the "bead" reference. My stock one has a raised lip, not a bead. Sort of like the lips you'd find on the timing chain cover and oil pan outer edges.
The rubber diaphragm must be in contact with the mounting pad on the fuel rails. The outer ring acts just like the removable rails that are on some of the oil pans; helps evenly distribute clamping force.
Think of it in the same way you'd install an oil pan. Gasket, oil pan, re-inforcing rails, bolts.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
[This message has been edited by JakeJr (edited February 20, 2001).]
Old Feb 21, 2001 | 05:06 PM
Dan91Z's Avatar
the ring won't fit over the adjustable housing.. should I just leave it out? The adjustable housing's bottom is about 3 times as thick as the orriginal too, so it seems almost like it wasn't intended to use a reinforcement ring.. unless I got screwed and they didn't send me one..
Here are some pics
<a href="http://www.marks-mall.com/orrig.jpg">This is how it was when I took it off orriginaly (don't seem right at all)</a>
<a href="http://www.marks-mall.com/adjust.jpg">Here are all the parts from the adj. regulator</a>
<a href="http://www.marks-mall.com/orig.jpg"All the orriginal parts, in the order they were while installed.. This makes me wonder if my car has been leaking the whole time i've owned it.. scary..</a>
<a href="http://www.marks-mall.com/thick.jpg">Thickness difference between old housing and new one</a>
<a href="http://www.marks-mall.com/nofit.jpg">The old ring not fitting over new housing.. it fits over the old one..</a>
so, am I susposed to have a reinforcement ring, or does this one not need one?
<a href="http://www.marks-mall.com/right.jpg">And this would be the right way to install it, if i don't need the reinforcement ring, right?</a>
It's weird that the old one was installed wrong like that.. I'm just glad my car didn't blow up or anything.. thank god it went out so soon.. oh well..
My `91 Z28 Convertible
Old Feb 22, 2001 | 10:29 AM
Mike89GTA's Avatar
I have the Accel too and didn't use the reinforcing ring. A year later and it's fine. The only problem is my el cheapo Accel fuel pressure guage is stuck, so I have to guess at what the FP is.
Old Feb 22, 2001 | 02:58 PM
JakeJr's Avatar
Axle/Gears: 3.07
From your pics, you don't need the reinforcing ring on the adjustable regulator.
The flange is so thick that it takes the place of the ring.
Just install the diaphragm, "quarter" housing and bolts. The rubber of the diaphragm will seal any leak.
Don't overtorque the bolts or they will snap.
Jake
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
