sensor question
Old Mar 19, 2004 | 11:07 PM
deadhead1882's Avatar
Car: 82 El Camino
Engine: built 355
Transmission: T-56 upgraded internal
Axle/Gears: 10 bolt 3.42
sensor question
what is the sensor on the passenger side of the block between 8 & 6 spark plugs, i broke the connector to it when i was changing the plugs tonight, if someone could tell me what sensor it is id appreciate it. Also can i just splice in a new connector with out having any problems, or is there something else id have to do to it.
Old Mar 19, 2004 | 11:39 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
sounds like a water temp. sensor. What do you mean by "broke"?
Old Mar 19, 2004 | 11:53 PM
Car: 82 El Camino
Engine: built 355
the plastic cover or whatever u wanna call it that snaps the metal thing into the sensor that completely broke off, all that is there is the metal thing
Old Mar 20, 2004 | 12:14 AM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Either the fan switch or the knock sensor.
The fan switch is the the head, the knock sensor is in the block.
I believe the wire to the fan switch is black.
Old Mar 20, 2004 | 12:16 AM
Car: 82 El Camino
Engine: built 355
i dont remeber the color of the wire, i actually believe it might be green but not sure. Its definetly in the block though
Old Mar 20, 2004 | 12:30 AM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
A few inchs from the starter right?
I'm pretty sure thats your knock sensor. I'm pretty sure I remember my wire being either green or blue, although someone told me it should be white.
If you go a few posts down there is a picture of the fan switch, just to make sure.
https://www.thirdgen.org/techbb2/sho...hreadid=228501
And what did you break, the clip that holds the wire into the sensor? I'm not sure if thats a seperate piece or not, you might need to put in a new sensor to get that piece, or you could ghetto rig it, but I didn't tell you to do that,
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
squiggy2
Aug 9, 2015 09:30 PM
