Which hedders should i put on my car?
Old Feb 22, 2001 | 12:47 PM
Jims83TA's Avatar
I have an '83 TA. It is a 350 (I know they didnt come stock with 350's), which the previous owner dropped in. Im not exactly sure, but I was told that the engine is a 350 4 bolt main. Firs of all, how would I tell if it is truly a 350 4 bolt main (a vette engine??)? Second question, which hedders are the best to put in my car? I have heard that the SLP's are really good, as well as the Hooker's. Which are better? Any other suggestions? I want to also put in a new flowmaster system, so which would help me get the most horsepower for my money? Thanks.
Old Feb 22, 2001 | 01:06 PM
GOLD85's Avatar
i'm running DYNOMAX headers.there 1 1/2s i think. they seem to do the job just fine
when the green flag drops the bull$hit stops
Curent: 350,performer RPM intake ,650dp, 700r4, headers, 3inch exhast
Spring 01: 406, Comp 282 solid cam, 2400 stall converter, every thing else the same.
R.I.P #3
Old Feb 22, 2001 | 03:22 PM
kane91z's Avatar
Car: 91 Z28
Engine: 5.7
the hookers are way cheaper than the slps - but you need to have a custom Y pipe made - Had mine done 3 inch for $150
91 z28 lb9 5 speed - hooker 1 5/8 headers - high flow cat- full 3 inch exhaust - home made ram air - tpis airfoil - dual chamber flowmaster - Stage 2 Jet Chip and 160 stat - 8 mm Msd plug wires - 55,000 v hypertech coil/rotor/distrib. cap - Mac. White face gauges - lots of sound system crap...
Old Feb 22, 2001 | 03:23 PM
Dan87IROC-Z's Avatar
Dynomax 1 1/2" headers are way to small for a 350 if my 1 5/8" Edelbrocks are too small for my 350. I would suggest the SLP 1 3/4" for the 350 if you have the money, if not, the TES are another good choice.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
Old Feb 22, 2001 | 06:40 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Hooker what needs a custom y-pipe? What they call their Super Comp Shorties, p/n 2055, comes with the y-pipe; 1-5/8" primaries, 3" inlet to the cat. Has AIR and O2 fittings as well. Still less than SLP's.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, WP 305 heads ported & polished, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
RazorN8
Jan 7, 2022 11:44 AM
TheExaminer
Aug 26, 2015 04:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
