serpentine brackets
Old Mar 20, 2004 | 09:09 PM
emtcee's Avatar
Car: 67 camaro
Engine: 383 accel dfi
Transmission: t56
serpentine brackets
i am putting a 383 tpi together and am trying to bolt on some serpentine brackets.there r 2 brackets ,obviosuly left and right.my problem is the passenger side bracket(right where the tensioner bolts to) when bolted on ends up right infront of the throttle body.are these the wrong brackets or something?i know that tbi truck use a one piece steel bracket.did different models or engines use similar brackets to tpi cars?because mine look the same as some of the pictures i've seen on this site but don't end up where its supposed to be.any help would be appreciated...
Old Mar 20, 2004 | 11:33 PM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
I have a set off a TBI 92 RS Camaro I parted out if that would help you. They were on a 4bolt 350 that someone swapped in there. I don't have the crank and wp pulleys but I do have the brackets and accessories.
Old Mar 21, 2004 | 07:10 AM
Steve86TA's Avatar
Car: To many to list
Is your bracket from an f-body?The trucks had different ones.
Old Mar 21, 2004 | 08:48 AM
emtcee's Avatar
Car: 67 camaro
Transmission: t56
don't really know what its from, i got them from a neighbor that was moving.
Old Mar 21, 2004 | 08:51 AM
emtcee's Avatar
Car: 67 camaro
Transmission: t56
hey TA5LiterHO do u have a picture of them so i can compare mine to yours?
jrdturbo
Mar 31, 2016 02:58 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
meeklay812
Oct 1, 2015 03:46 PM
armybyrd
Sep 26, 2015 03:37 PM
