Oxygen Sensor Questions
Old Mar 21, 2004 | 05:54 PM
tlgrooms's Avatar
Car: '69 Camaro/'91 Camaro/'93 Camaro
Engine: 307/305/350 LT1
Transmission: Powerglide/Auto
I've got a '91 RS 305 Automatic and want to replace my Oxygen sensor. Can anyone tell me where its located? Hard to get to? Will I have to go under the car to get to it?
tnx
Tim
Old Mar 21, 2004 | 06:40 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It is on the driver's side exhaust manifold. Just open the hood and stand over the driver side fender. Look down and you should see it. You need a 1" or 15/16" closed end wrench I believe. It may be easier to change it from the bottom but I think it can be done from the top.
Old Mar 21, 2004 | 10:35 PM
Vader's Avatar
What Shifty said. Usually, you can change them from teh top:
Old Mar 25, 2004 | 04:15 AM
Tom91RS's Avatar
Car: 91 Camaro RS
Engine: 305 tbi
O2 sensor effect gas mileage ?
I have heard a bad sensor will cause bad gas mileage. We have a 305 TBI 91RS that sucks the gas. All standard tune-up items replaced.
Old Mar 25, 2004 | 01:56 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Re: O2 sensor effect gas mileage ?
DEFINITELY. probably the #1 thing that will hurt mileage. When I bought my car it had a bad o2 sensor, and got maybe 9 mpg and ran really rich (black smoke out the exhaust). I changed it and it shot up to about 20.
Old Mar 26, 2004 | 09:51 AM
tlgrooms's Avatar
Vader and Shifty:
Really appreciate the info, esp the pic. Going to change my sensor tomorrow. Really hard to see it on my car but can see it thanks to you pointing out the location with the pic.
Now, if I can ever get my speedometer working again!
Tim
Old Mar 27, 2004 | 11:39 AM
Vader's Avatar
Speedo? (Not the swimwear.)
If I'm correct, the '91 Camaros finally got an electronic speedometer and used the VSS at the transmission like the Firebirds had since 1986. Make sure your's is connected:
Old Mar 27, 2004 | 04:56 PM
tlgrooms's Avatar
Vader,
Yep, it's connected. I replaced mine with another one that I got at a salvage yard. That may be my problem. Not sure. I was getting a VSS error after hooking my laptop up to the car along with an oxygen sensor and tps low error. Today I replaced my oxygen sensor and disconnected the battery and reconnected and now all 3 errors are gone. BUT, my speedometer is still not working and I was not getting a reading in the program on my laptop either for speed. Does that mean it's definately a wiring problem?
Thanks much for the help.
Tim
Old Apr 24, 2004 | 05:54 AM
Tom91RS's Avatar
Car: 91 Camaro RS
Engine: 305 tbi
does the 02 sensor work
if the converter has been removed. I have heard it will send a false reading if the converter has been removed. I was also told you can buy a "fake" 02 sensor replacement that will fool the computer. The car gets really bad gas mileage.
Old Apr 24, 2004 | 01:02 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
The fake o2 sensor is for the o2 sensors that are after the cat. We dont have those sensors on our cars. You dont want to use that for the sensor that is in front of the cat.
Old Apr 24, 2004 | 06:55 PM
Tom91RS's Avatar
Car: 91 Camaro RS
Engine: 305 tbi
So should I still replace the 02 sensor ?????
if I don't have a converter ? It sounds like I should
Old Apr 25, 2004 | 12:05 PM
Vader's Avatar
It isn't necessarily a wiring problem. The VSS is operated by a steel drive gear pressed on the tailshaft, and a plastic driven gear on the VSS thimble. Make sure the plastic gear is in place and intact. When you remove the VSS to check that, look inside the housing to see if the steel drive gear is centered in the opening, so it will mesh the driven gear properly.
Another thing you can do is connect the VSS electrical connector, turn on the ignition, and have an assistant watch the speedometer/odometer while you manually turn the VSS thimble.
Old Apr 25, 2004 | 03:58 PM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
If you have headers...will this sensor be in the same location?
Old Apr 25, 2004 | 09:27 PM
Vader's Avatar
Nope. Not necessarily. It could be mounted anywhere.
Old Apr 25, 2004 | 10:33 PM
BadBowtie88's Avatar
This is true. I bought some Hedmen's and had to drill the hole in driver's side and weld in the insert for my sensor.
Old Apr 26, 2004 | 06:52 AM
ThraxXx's Avatar
I guess I will hunt for an addapter that looks like the one in this picture. I am thinking my O2 Sensor is off and needs replacing as my exhaust has a rich gas like smell to it.
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
beast94
Aug 20, 2015 06:44 AM
redmaroz
Aug 16, 2015 11:40 PM
squiggy2
Aug 9, 2015 09:30 PM
