starter and flexplate question
Old Mar 21, 2004 | 06:54 PM
TheViper's Avatar
Car: '84 Z28
Transmission: th2004r
i have an 87 350 i'm building for my 84 camaro. it has the big 14" flexplate so i know i'l need the small one. if i got one off of a 87 camaro with a 305 would it work? also, what starter would it use? thx
it has a 67 283 in it right now and i forgot what starter it has. would it use the same one?
Old Mar 22, 2004 | 05:01 AM
ede's Avatar
ede
should work long as both have the same type rear main seal
Old Mar 22, 2004 | 07:49 AM
mike89-350's Avatar
Car: 89 formula 350
Engine: 355
The flexplate will work. You need a starter with the straight across bolt pattern. If you got one with the offset bolt pattern a starter shop can change nose for the other pattern.
84z96L31vortec
Aug 20, 2017 12:16 AM
Cleotiz
Aug 22, 2015 01:54 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
Leggman1
Aug 6, 2015 04:15 AM
