TPS on 92 350 TPI
Old Mar 21, 2004 | 11:19 PM
rtkjadams's Avatar
Car: 92 Camaro Z28
TPS on 92 350 TPI
What should the TPS voltage be set at? 92 Z28 5.7 TPI, Auto
Thanks,
Ray
Old Mar 22, 2004 | 07:15 AM
pigsticker's Avatar
Car: 1992 z28
Engine: Vortec 350 TPI
O.54 volts or real close to it.
Old Mar 22, 2004 | 11:33 AM
Firebreather's Avatar
Car: 1991 GTA
Engine: SuperRam 350
I read in the SuperRam instructions that 90-92 should read around 0.70 V and pre 90 should read around 0.54 V. Anyone knows about this?
Old Mar 22, 2004 | 11:35 AM
Car: 1991 GTA
START UP AND CHECK OUT
1.Check TPS voltage.
1985-89 Idle voltage should be .54 volts
1990-91 Idle voltage should be .70 volts
2.Check initial timing and reset to 6 degrees (with ignition bypass disconnected) for best performance.
Please note: Retard timing if you have any problems with detonation.
3.Your Idle Air Control motor (IAC) may need to be adjusted to allow the computer to provide proper idle. See GM service manual for instructions.
Old Mar 22, 2004 | 11:57 AM
pigsticker's Avatar
Car: 1992 z28
Hmmmm, I haven't heard that. Is that .70 reading just for a SupeRam setup or does it apply to a stock TPI setup?
Old Mar 22, 2004 | 01:40 PM
Car: 1991 GTA
I have no idea
Old Mar 22, 2004 | 08:49 PM
rtkjadams's Avatar
Car: 92 Camaro Z28
.70 sounds right. Because when I checked it, it was at .67 and I got it down to .60 and the car doesn't run as good.
Also, as far as the timing: should it be 6* BTDC or ATDC ?
IAC adjustment: how is this done?
Thanks guys,
Ray Adams
Old Mar 22, 2004 | 09:20 PM
Vader's Avatar
Either '90 or '91-later TPIs have a non-adjustable TPS. They should be at less than 1.0 but more than 0.60VDC in the closed throttle position for the ECM to correctly "learn" the closed throttle position during system power-up.
Old Mar 22, 2004 | 09:23 PM
Vader's Avatar
Also, there is no adjustment for the IAC. The ECM does all the positioning of the stepper motor pintle depending upon inputs. What you need to adjust is the minimum air position of the throttle plates at hot idle so the IAC and ECM can correctly control idle RPM.
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
