Dead miss
Old Mar 22, 2004 | 10:17 PM
Eric 91RS's Avatar
Car: 92 Chevy 1500
Engine: 350 TBI
Transmission: TH-700R4
Dead miss
When my TBI RS is at idle #8 cylinder is not running. Any wire i unplug changes the motor except #8, but #8 plug is getting good fire. Also at idle the lights get dimmer when it misses. This is getting real anoying, i have changed or checked everyting ignition related. Can a roller cam wear a lobe I hope its not internal IT has even compression #s
There could be something simple that i am overlooking.
Its been this way since i wrecked the car, it sat up for a couple of months while i fixed it
Old Mar 22, 2004 | 11:02 PM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
Have you replaced the spark plug? I know you said it had spark on #8, just didn't know whether you meant at the end of #8 wire or at the end of the #8 spark plug. I would go through and change all the plugs first then go from there. Make sure that #8 wire isn't melted through and grounding out on something also.
Old Mar 23, 2004 | 12:02 PM
Eric 91RS's Avatar
Car: 92 Chevy 1500
Engine: 350 TBI
yes the plug is good
Fireslash
Apr 11, 2016 06:43 PM
BrianI
Oct 3, 2015 12:57 PM
lewandom
Oct 1, 2015 08:15 AM
92projectcamaro
Sep 29, 2015 07:07 PM
raymondandretti
Sep 27, 2015 06:43 PM
