Car wont start
Old Feb 23, 2001 | 01:28 PM
88RocRookie's Avatar
Car wont start
Hi guys, I just wanted to know if there is a way I could jump start my car if the starter is dead. And also, is it pretty hard to replace the starter? What type of problems am I going to run into if any? Thanx for any help you guys can offer.
P.S. The symptom my car is having is when I go to start it, there is just a clicking sound everytime I turn the ignition. Starter problem?
Old Feb 23, 2001 | 03:09 PM
R.O.B.'s Avatar
Just clicking could be battery, solinoid, starter, or connection. First look at the battery. Are the cabels loose, look corroded, or burnt in anyway? Check the battery itself by taking it to Autozone and having them do a load test. If it comes back ok, then you have a starter problem.
As for jumpstarting your car, it will only do this if it is actually the battery that has the problem, if the starter is fried, it won't work. Although if you have a stick shift, you can just push start it.
Rob
'86 TA 305 TPI
Gutted MAF
Ported Plenum
TB Bypass
Old Feb 23, 2001 | 04:17 PM
The ODB's Avatar
I second what Rob said.
Old Feb 23, 2001 | 08:55 PM
Thanks for the info fellas, Ive tried jumping it before but I'll take it to Autozone tommorrow and test the battery anyway.
Old Feb 24, 2001 | 12:30 AM
Neo's Avatar
Neo
As for replacing the starter I did it tonight, you will need a 1/2" socket, a 9/16" socket, 5/16" socket, a rachet, few extensions, and wrenches of the same sizes. Remove connections to your battery. There are two bolts (9/16") actually holding the starter. Then there are three other bolts that have wires on them. But only two have wires on them. One is 1/2" and the other is 5/16". Remove these very easily. You might need a pipe to give you added leverage(I did). Make sure you do not get the wires hooked up, three to the larger post and one to the smaller. Hope this helps
Mike Kenny
Current: 1991 RS 305 TBI
Past: 1990 RS 305 TBI (A woman forgot what red lights are for)
Current: mostly stock - newer 305 w/ 12,000 on it
Eclipse speakers all around w/ 10" tube powered by a Alpine V12 in back
K&N filter w/XStream flow lid - It is sweet!!
Future: 2" Cowl hood
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
