Smog Delete Plug
Old Mar 23, 2004 | 08:54 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Smog Delete Plug
I'm getting ready to take the smog pump off my engine, and am having problems finding a plug for the hole in the exhaust manifold.
I measured it to be around 7/8 or 22mm. Does anyone know of the correct size and thread count? Or where to get one?
Old Mar 23, 2004 | 10:16 AM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
you probably won't find a plug thats exactly the correct size, i know i couldn't ,
i got some brass pipe plugs, but don't remember the size, i used the brass, cuz it seems softer than steel so the threads would adjust for the slightly different threads and seal up well
Old Mar 23, 2004 | 10:50 AM
Dale's Avatar
Engine: 350 S-TPI
Do you remember what size/pitch you bought?
I assume it doesnt leak either?
Old Mar 23, 2004 | 12:42 PM
Dale's Avatar
Engine: 350 S-TPI
Found something! 5/8 flare fitting! Appears to be it. Like 3 bux from hardwear store. Will have to cut the "flare" part off, but nothing the air tools wont fix in a few minutes.
italiano67
Dec 11, 2016 09:21 AM
LittleFranks
Sep 17, 2015 12:22 PM
g.l.mos
Aug 22, 2015 12:02 AM
BlackphantomZ28
Aug 21, 2015 07:12 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
