2 engine symptoms..probably transmission?
Old Feb 24, 2001 | 07:40 AM
jtb510's Avatar
I've noticed two problems on my 86 iroc (automatic) that are making me a bit nervous.
First: when the engine's cold, it's hesitant and shakes when I touch the gas pedal in reverse.
Second: At higher RPM's on the freeway, (between 15 and 25) when it's held at a constant speed the engine stutters. It slightly revs and then falters, only by a few rpm but I'm afraid of what it's syptomatic of...
Any suggestions about what it could be?
Thanks.
Old Feb 24, 2001 | 09:38 PM
snakeskinner's Avatar
those are things someone needs to experience to diagnose. could be several things and are hard to pinpoint diagnosis over a keyboard.
Kyle Osterholt
Okarche, Oklahoma
ASE Master Certified
86 T/A 383 TPI
89 TTA #1002 T-top/Leather
89 TTA #1358 Hardtop/Leather
80 T/A Pace Car
73 Opel GT
73 bronco
Old Feb 24, 2001 | 11:47 PM
Vader's Avatar
JTB,
If your IROC is a TPI, check the PROM in the ECM. GM had a TSB on the original PROMs that addressed the low RPM "chuggle" and several other issues. There is a replacement PROM available for about $50.00. My '86 TA acted like a different car with the improved programming.
Later,
Vader
"No matter how hard you try you can't stop us now..."
Adobe Acrobat Reader 4.0
jhawkeye
May 25, 2022 06:33 PM
Vintageracer
Jan 10, 2020 05:33 PM
E Rod
Aug 28, 2015 05:17 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
milk
Aug 10, 2015 06:26 PM
