Need help changing fuel filter fast!!
Old Feb 24, 2001 | 08:04 PM
Enkil's Avatar
Okay, so I go to change my fuel filter tonight because it's never been done as far as I know. I take the inline fuse out, and the fuse out of the fuse panel, for the fuel pump... Crank the engine over to let all the remaining fuel empty out.. I even made sure by noticing that zero fuel was coming out of the injectors.. Then I go and open the gascap to depressurize the tank. So I think I'm fine. Then, when I go to unbolt the fuel filter, gas just keeps coming out of it. So far I've filled two snapple bottles with gas. Is this normal? Will it keep draining until the entire tank is empty? Or do I just need to be really fast about getting the old oneoff and putting the new one on?
Oh, by the way.. I did have the back end of the car on ramps for a while to get to it easier. I read a post that that would cause it to leak because of gravity so I coasted off the ramps and now have the front end up on jackstands to try to prevent that again. It's still trickling right now though, HOPEfully only from residual gas in the lines.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
[This message has been edited by Enkil (edited February 24, 2001).]
Old Feb 24, 2001 | 08:47 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
There is a check valve in the pump. The gas you see is coming from the lines and fuel rails.
Old Feb 24, 2001 | 10:20 PM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
When I changed the fuel filter in my 89 RS I had the exact same problem. What I determined is, yes the fuel coming from the tank will just keep draining. What I did was use some vise-grips and lightly clamp the rubber hose higher up. and presto the fuel stopped. then changing the filter was very easy.
89 RS Camaro, 305 TBI
Mostly Stock
Duel Snorkel Air intake
- Future Mods -
DynoMax Street Headers
DynoMax Cat Back
Old Feb 25, 2001 | 12:31 AM
KS91Z28's Avatar
Opening your gas cap will only help the siphon.
Old Feb 25, 2001 | 09:27 AM
Enkil's Avatar
Yeah, I realized that after the tank was depressurized I should put the gascap back on. Well, now my only problem is I can't seem to get one of the bolts back on. But that'll just require some wiggling and what-not.
1992 Trans Am
May 10, 2023 07:19 PM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
Logan Bryant
Aug 27, 2015 11:52 AM
92camaroJoe
Aug 13, 2015 06:07 AM
