High TPS voltage = what?
Old Mar 25, 2004 | 09:01 PM
87Formula4bbl's Avatar
Car: '87 Formula
Ok, I did a search and didnt come up with anything.
Problem: Got my new carb from i-Five out in Cali, carb looks awesome, like new, all new parts and seals, gaskets, and brass bushings, and linkage replated and body recolored. Everything is great, props to them. BUT, I asked that they leave the plugs out in case I wanted to adjust something, you never know. They left them all out but one, the TPS plug. Just out of curiosity today, I tested the TPS and it tested at 1.33V throttle fully closed. Should be at ~ 0.48V right? I think so. I wont be able to get the plug out for a while (no cordless drill and am not removing the carb just for that), so I'm asking does anyone know what this would do to performance?
Old Mar 26, 2004 | 01:53 PM
Car: '87 Formula
Thanks for the replies
Well, I fixed it today. I just pulled the carb, drilled with a 7/64" bit and used a screw, and reinstalled. Set the voltage to 0.49V.
Before: Cruise seemed a little rough, just the slightest roughness in the engine (shaking).
After: Car runs flawlessly. I think it was throwing in too much timing at cruise speeds. Now I just gotta get the secondaries dialed in. AV tension is at 1/4 turn, has a new pulloff. Using B hanger and DA rods right now. Getting a slight hesitation, not bog tho. Should I step up to 'lower' rods?
BumpaD82
Feb 26, 2016 02:57 PM
86IROC112
Nov 27, 2015 09:54 AM
eustodp
Sep 20, 2015 05:09 PM
ULTM8Z
Sep 16, 2015 09:15 AM
