Car is backfiring, what should I do?
Old Feb 25, 2001 | 05:52 PM
Dan87IROC-Z's Avatar
I got my car running with my new cam, finally, and it backfires like a mother at WOT, what should I do??
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
Old Feb 25, 2001 | 06:02 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
Check your timing, plugs, wires, module, coil, rotor!!
Did you degree in the cam?? I don't know who makes the LT4 hot cam but if it's not Crane or Comp then you can't install it straight up and expect it to run properly!!
The only thing else I can think is it could be the chip! You must need to upgrade to an aftermarket...most likely a custom chip!!
1986 Trans AM
305 TPI
200,000+ miles (speedo/odometer non-funtional! Odometer reads 142,000)
4 Wheel Discs
9 bolt Borg Warner Rear (2.73's....oh joy) :P
Completely Stock
Soon to upgrade to a 350 converted from TPI to Carb, Edelbrock 750CFM Carb, Edelbrock Performer RPM Intake, Headman Shorty Headers, Some sort of ported heads (undecided), XE268 Cam, Moroso HEI ignition kit with external MSD Blaster II Coil and an MSD 6-AL Box!!
Current project: Keeping my 305 running until I get my income tax returns!
Old Feb 25, 2001 | 06:03 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Hows the valve lash??
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
My favorite quote about D.E. "He can see air"
Old Feb 25, 2001 | 06:10 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
From the exaust or the intake?
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Feb 25, 2001 | 07:20 PM
I did install it straight up, lined up the timing marks on the new timing chain so thats all good. It could be the valve lash though, the car lacks MAJOR power and moves through the RPMs slower than it used to, like its not really floored or somthing.
L98 TPI 350 (5.7L)
Old Feb 25, 2001 | 08:05 PM
theformula's Avatar
Maybe your fuel pressure is to high? Just a thought
[This message has been edited by theformula (edited February 25, 2001).]
Old Feb 25, 2001 | 08:22 PM
Yea, could the valve lash or running too much fuel pressure make it smell like gas like a mother? It smells like a have a full service gas station in my garage, its pretty bad.
L98 TPI 350 (5.7L)
Old Feb 25, 2001 | 09:17 PM
Camaroman's Avatar
My '84 did that before I put it away....
my problem was my rochester gone bad...
new carb...no problem
Old Feb 25, 2001 | 10:55 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Hey dan, did you ever set the base timing? If I recall in an earlier post, you hadn't yet.
Also, recheck the plug wire routing.
Old Feb 25, 2001 | 11:22 PM
theformula's Avatar
Dan, while running fp of 47-52 I noticed I was getting backfiring when I shifted.
Try setting the fp around 44psi and see what happens. Just don't get on it too hard!
Old Feb 25, 2001 | 11:31 PM
Bort62's Avatar
Okay, I know this is Obvious, But You didnt use the stock valvesprings did you ?
I dont see it in your Mod list, So I guess its possible, If you did you could be getting float at RPM and hence backfiring, Wich would be the least of your problems
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Feb 26, 2001 | 02:48 AM
Yes, I did get new valve springs and I had a machine shop install them for me. What do I have to do about that?
L98 TPI 350 (5.7L)
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
