Alright, my shifter linkage has come off 3 times now...this is annoying!
Old Feb 24, 2001 | 11:08 AM
crazeinc's Avatar
Hey guys. A few months ago I hooked up a TCC lockup switch, but in the process of doing so I uncoupled the shifter linkage to have some better access and put it all back together when I was finished.
2 months later (really only driven about 5 miles since then) the shifter wasn't working so I checked the linkage and sure enough it came off of its bracket. Stuck it back on and it felt damn secure.
Yesterday it came off again and now I'm wondering if there's something I'm missing.
There's a holder for the linkage and then on the linkage itself there's a clip type thing that slides into this holder to keep it in place. Is there something else that's supposed to go there to prevent it from falling off because that's not working!
Thanks.
1982 Camaro Z28
should be running 11's this spring...we'll see
Check the website for progress http://members.fbody.com/Pro82Z/
Old Feb 24, 2001 | 04:09 PM
crazeinc's Avatar
Somebody please...I literally almost killed myself yesterday because I was in a hurry trying to fix this.
Old Feb 24, 2001 | 08:12 PM
84FTA's Avatar
Are you saying it's sliding out of the bracket that bolts to the oil pan or the "arm" (memory fails me now!) that goes into the valve body that the end is attached to?
1984 WS6 Trans Am Hartop
Former L69 Car under restoration
1984 Trans Am T-tops
4-bolt main 350, performer intake, headers, Holley 650, T-5, hayes clutch, dual elec. fans and 3.23's.
Daily driver and restoration
13.98 @ 101
Old Feb 24, 2001 | 09:24 PM
crazeinc's Avatar
Yes...i can't figure it out. It fits in there so snugly but somehow it works its way off.
Old Feb 25, 2001 | 03:19 PM
crazeinc's Avatar
Vader? Is it just supposed to slide into place and theoretically not slide out?
Old Feb 26, 2001 | 04:57 PM
crazeinc's Avatar
Maybe a moderator should move this to the Transmission section?
Street Lethal
Apr 30, 2019 12:14 PM
NBrehm
Aug 25, 2015 11:49 PM
neekolzun
Aug 24, 2015 04:59 PM
Out-Cast
Aug 22, 2015 07:49 PM
Dialed_In
Aug 20, 2015 01:45 PM
