please someone help!! i need pics of power steering mount possition!
Old Mar 27, 2004 | 10:44 PM
XChris1632X's Avatar
Car: 83 Z-28
Engine: LG4 305
im finally getting my car back together tonight and my buddies and i cant figure out how to mount my power steering pump back on. i may be missing a bracket. i had to get some new brackets because some were bent from my accident. i havent worked on this car for two years because of money status. i the only thing keeping me back is this power steering pump. i just need a picture of how they mount up. i have a v-belt setup in my 83 on a 305. it was originally a a/c car but my little brother threw out the a/c compressor and any brackets with it, i hope that doesnt matter. please help soon so i can finish my car tonight.
thanks
Old Mar 27, 2004 | 10:57 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Gee that was stooopid of me!!!! Try this.
https://www.thirdgen.org/techbb2/sho...hreadid=226636
Old Mar 27, 2004 | 11:45 PM
3gc's Avatar
3gc
Car: Z28
Also, to add to that, as long as only A/C brackets were thrown away your ok. If I remember correctly, you only need the bracket that goes on the powersteering pump and the one that goes from the block to the first header bolt.
Old Mar 28, 2004 | 12:59 AM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
seein as how I'm the goofball who needed those wondeful pics in the first place, I can verify the length of the spacer in that pic. it's 1 1/2 inches long. if you're using LT headers.... you may not be able to use the upper bracket..... but honestly, if you retain the others, you'll be ok. I know you said the A/C is gone... but you may want to go junkyarding and find the compressor and brackets from another car. if you can't, lemme know, and I might could get you the brackets you need.
Old Mar 28, 2004 | 12:03 PM
Car: 83 Z-28
Engine: LG4 305
i am going to try to make a trip to the junkyard because i believe im missing a bracket. im going to just take all of the brackets for the accesories i can get that way i know i wont be missing any. i also have one bracket thats broken, and one thats bent. needless to say there is not much i can do until i get to the yard and find some brackets. as long as i find a v-belt f-body will all of them have the same mounting peices.
Old Mar 28, 2004 | 12:07 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Doesn't even have to be a F-car.... Caprices, Cutlasses, MCs, etc. with Chevy V8s from 82 or so up until they changed to the 1 flat belt and a couple of V-belts, in about 86 or 87, will do fine.
Old Mar 28, 2004 | 11:34 PM
Car: 1982 Trans Am
Engine: 383 chevy
close..... but it was 85. ask me how I know look for an 80-84 caprice or monty C or f-body V8. jack all the brackets.
Jeremys87
Jul 14, 2022 09:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
Bert87
Aug 23, 2015 03:50 PM
