need some quick motor help
Old Mar 1, 2004 | 09:49 PM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
silly question, but important, none the less. I have an 82 t/a... i pulled all the accessories off of my 305, to put them on the 350 i'm putting in. I can't figure out how to mount the damn Power steering pump. it's a carb 305, if that makes a difference, and all the other acc's bolt on just fine. I just need to find out where the hell the power steering pump bolts to. any pictures would be GREAT. also, the pump has a 2-groove pulley if that's important to know. Thanks in advance for all your help guys!
Old Mar 2, 2004 | 01:04 AM
dangerousd89's Avatar
Car: so many projects to little time
Engine: 350 tbi
my 350 has a bracket that mounts to the head and an arm that mounts to the first header bolt on the drivers side. my pump has a bolt in the back that the bracket mounts to.
Old Mar 2, 2004 | 01:12 AM
Car: 1982 Trans Am
Engine: 383 chevy
thanks for the help,but I was wondering ehre the holes on the left side of the pump (as you're facing it) go. they line up to some of the holes on the front of the motor, i just dunno where. any thoughts? preferably pictures? (it may be important to mention that my motr is a carb 350 with a carb 305 acc setup.)
Old Mar 2, 2004 | 01:19 AM
Engine: 350 tbi
sorry mine only has the bracket and the arm...
Old Mar 2, 2004 | 09:05 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It doesn't matter that it's a 350, as long as the heads have the accessorey bolt holes in them. All SBCs are the same in this regard.
I have some pics at home showing the bracket assembly onto the engine. I'll post them later.
Old Mar 2, 2004 | 09:59 AM
Car: 1982 Trans Am
Engine: 383 chevy
RB, you're the shiznit, bro. thanks for all the help guys.
Old Mar 2, 2004 | 06:03 PM
Car: 1982 Trans Am
Engine: 383 chevy
anybody else?
Old Mar 2, 2004 | 06:13 PM
smithtc's Avatar
LOL.
I don't have pictures...but I once took my power steering pump off without knowing that there were 2 bolts in that area. I no longer have that part of the bracket on my power steering pump now. One of the bolts is used for the ground from the battery. I left the other bolt out. No problems running is this way so far.
It's the only two bolt holes in the area, one on top of the other. East of the timing cover, and southwest of the freeze plug.
Old Mar 2, 2004 | 06:30 PM
Car: 1982 Trans Am
Engine: 383 chevy
****... so I put it on wrong? i put that plate you speak of on the water pump, northwest of the timing cover. that might explain why i can't figure out how to mount it up. thanks. anybody with pics of this is welcome to post anyway though.
Old Mar 2, 2004 | 06:58 PM
smithtc's Avatar
http://f2.pg.photos.yahoo.com/ph/gta...bum?.dir=/9cbb
Pics of a block...350
My power steering goes on the driver side on the bottom right (facing engine). Alternator on top right, smoag pump was on bottom left, and air conditioner compressor is on top left. (facing engine)
Old Mar 2, 2004 | 07:58 PM
Car: 1982 Trans Am
Engine: 383 chevy
thanks man. I'm look for a pic of the assembled motor, though... like, basically some way of saying "hey, that's how it goes..." basicaly just need pics of which holes to use, cuz the guy i got the car from started taking it apart to rebuild the motor before i got it.
Old Mar 2, 2004 | 08:29 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Here's how the one fits that goes across the front.... It goes on the manifold bolt, and goes down to the front of the block
Old Mar 2, 2004 | 08:30 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Another....
Old Mar 2, 2004 | 08:31 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Then some of the others go on the front of the head
Old Mar 2, 2004 | 08:32 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Here's how the pump goes on
Old Mar 2, 2004 | 08:39 PM
Car: 1982 Trans Am
Engine: 383 chevy
you are the man. WE HAVE A WINNER!!!
:hail: :hail: :hail: RB83L69 :hail: :hail: :hail:
Old Mar 3, 2004 | 10:16 AM
Car: 1982 Trans Am
Engine: 383 chevy
one last question... how big was that spacer you used, and how did you make it?
Old Mar 3, 2004 | 10:26 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Couldn't tell you how big it was.... it came with the headers, but was the wrong length (too long); I set the header and manifold next to each other, and cut the spacer to be the difference in thickness between the manifold and the header flange. Then I used the stock hardware; the stud, all the washers, etc.
You could easily use a piece of steel pipe with 3/8" ID as raw material.
Old Mar 3, 2004 | 12:17 PM
Car: 1982 Trans Am
Engine: 383 chevy
thanks. you've been a huge help. take care!
Old Mar 27, 2004 | 10:54 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Here's a few...
https://www.thirdgen.org/techbb2/sho...hreadid=226636
mike_c
Aug 27, 2015 04:32 PM
happyhapka
Aug 15, 2015 04:42 PM
L98GTA87
Aug 5, 2015 11:02 PM
