changing spark plugs help...
Old Mar 27, 2004 | 10:53 PM
JeffC1500TBI's Avatar
I was wondering if anyone had tips or ideas for changing my plugs.. with the headers on there there's no room to get a spark plug socket on some of the plugs.. I end up having to use a 1/2 " drive socket so that it slips over the whole plug and then use vise grips to turn the socket.. it's a real pita. some of them I have to do from under the truck.. can I buy shorter plugs or will that be a problem with the plug boots?
thanks
Old Mar 27, 2004 | 11:51 PM
3gc's Avatar
3gc
Car: Z28
Try a 5/8" offset wrench. I can get all my plugs pretty easy with it.
Old Mar 28, 2004 | 12:08 AM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
I think they do make shorter plugs, and probably wires to match. The boots are just rubber though, they can be cut cannot they?
This looks like it may work too
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2470054034
Old Mar 28, 2004 | 12:20 AM
DC87GTA's Avatar
Car: 1987 Pontiac GTA
Engine: ZZ383 HSR
Transmission: T-56 6-Speed Manual
Axle/Gears: Ford 9", 3.89 TrueTrac Posi
If you have a spare socket, doesn't necessarily have to be a spark plug socket, get access to a bench grinder and go to work. I did this when I was trying to change the plugs in my buddies drag van with a supercharged 468 motor. Just shortened it a bit, and tapered the ratchet side of the socket to allow clearance to get it on the plug. Worked great and still was able to use a ratchet.
Old Mar 28, 2004 | 12:25 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I did something similar for my '71 Camaro.
I also used a 1/2" drive socket, but ground two adjacent flat spots on it so I could grab it with Chanel-Locks.
Works like a charm.
Old Mar 28, 2004 | 12:31 AM
25THRSS's Avatar
http://www.slponline.com/view_produc...&SHOWEMAIL=Off
Old Mar 28, 2004 | 02:38 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Re: changing spark plugs help...
thanks
This is a good reason for you to go with Bosch Platinum single prongs plugs. They are shorter and will thus give you easier access, and they will last for 3 or 4 years easily, saving you the aggravation of pulling them every year (or six months).
Old Mar 30, 2004 | 07:31 AM
thkanks..
Thanks for all the replies.. I had to 5/8 spark plug sockets.. so I took the zip cut to one of them and honed it out a little with the dye grinder. works GREAT.. I have to get under the truck for one of the plugs but I can do all of them with the new socket & wrench. takes about 1/3 of the time.
Old Mar 30, 2004 | 07:50 AM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Why don't you like going under to do it. You get to lay down while you work
Old Mar 30, 2004 | 06:19 PM
IceBlue91z28's Avatar
Car: 1991 Camaro Z28
Transmission: Built 700r4
yup going under works the best
Old Mar 31, 2004 | 06:43 AM
iroc-si's Avatar
Car: 1985 Chevy Camaro IROC-Z
Engine: 350ci from 79camaro
Transmission: 5 speed manual on lsd
Do as 3GC says and get the 5/8" offset wrench. It works. no need to work from below, or mess around modding tools, it just works.
Si. :lala:
Also do a search next time, this comes up every couple of weeks!
eightsixseven
Dec 16, 2024 01:50 PM
apo_bailon15
Mar 28, 2016 05:20 AM
evilstuie
Feb 28, 2016 03:33 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
