TPI or CARB
Old Feb 26, 2001 | 01:33 AM
v6-3.1's Avatar
TPI or CARB
Which is better in terms of speed. How do 350's come.
Old Feb 26, 2001 | 01:47 AM
Enkil's Avatar
Well, TPI systems are more adept at making torque. 350's came with TPI, TBI and carbs I think.. not too sure. Each system has it's perks. For instance, carbs are relatively cheap and when properly tuned can put out great amounts of power. TPI's can put out great amounts of power as well, but are a LOT more expensive. On the upside, emissions testing is usually easier to pass with a fuel injected (TPI/TBI/EFI/MPFI) system.
If budget is a concern and emissions isn't, I'd say go with a carb.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Feb 26, 2001 | 01:52 AM
Spyder's Avatar
Well TPI is nice, if you don't have to work with state laws go with carb. Nice and simple, no computers, no worry about proms, no sensors to go bad. If you looking for power and gas mileage and you have lots of money then TPI is the way to go. If you want power with less hassle but you will give up some gas mileage carb. Not to mention there is thousands of parts :-) its been arounds forever!
--Spyder--
1992 Camaro RS
LO3, T-56,centerforce clutch, ported and polished heads, Edelbrock Performer Intake, 14X3 Open Element w/ K&N, hiflow cats (and thats it), AC delete, alu drive shaft, 170 stat w/ fan switch, STB, Subframe connectors, KYB AGX, Eagle GSC, and poly bushings.
1982 Z-28
Project car, ZZ4 in the works.
Old Feb 26, 2001 | 05:25 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
In third gens 350s only came with TPI. Fuel injection is alot less hassle, and alot easier to diognose. Carb isn't as efficient, and with out a computer, you really can't change elevation too much. Even the LG4s with the feed back quads won't let you be at peak performance when going up, or down 1000 or so feet in elevation. But, for the money, carb is the way to go. The intake alone for TPI is around $2000 new. Show me an intire carb, cleaner, intake, gaskets, and header system,(for the street) that costs that much!!!!!
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Old Feb 26, 2001 | 11:11 PM
Bort62's Avatar
As Much as I recommend People Use carbs When they can, If I had a Complete used TPI setup with harness show Up In the Mail tomarrow, I would stay home from School All this week Installing it )
Im really just a Sucker For Changeing things. EFI Lg4, Carbed L98, Wichever Way You like it.
They both have their ups and downs, Carb is Deifnately easier to get going intially.
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
gta90
Sep 15, 2015 04:00 PM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
