non EGR intake with computer carb
Old Feb 25, 2001 | 08:36 PM
Troy 85Z's Avatar
Car: 85 Z
Engine: Edelbrock Injected 350
Axle/Gears: 3:42 LS1 Posi
What effects will running a non EGR intake have on the stock computer and carb? I've been told it will always run lean without EGR but won't the carb adjust the mixture accordingly. Also, will the check engine light always be on or will the computer not know the difference? Anybody running this kind of combo let me know how well it works or any problems you've had. Thanks
Old Feb 25, 2001 | 10:02 PM
snakeskinner's Avatar
egr has nothing to do with air/fuel ratio. The only effects you would see is possible increase in detonation. EGR simply cools down the combusustion temperature which lessens the threat of detonation.
Kyle Osterholt
Okarche, Oklahoma
ASE Master Certified
86 T/A 383 TPI
89 TTA #1002 T-top/Leather
89 TTA #1358 Hardtop/Leather
80 T/A Pace Car
73 Opel GT
73 bronco
Old Feb 26, 2001 | 02:11 PM
Troy 85Z's Avatar
Car: 85 Z
Will the check engine light be on when the computer doesn't "see" any EGR. I don't really know everything the computer controls on the early carb cars but I'm worried about drivability problems with disconnecting it. I don't think I'll have a detonation problem with my current setup though. Thanks
Old Feb 26, 2001 | 03:16 PM
Bort62's Avatar
Well, I thought it would Code, But I took every emissions peice off My friends 86 Z28 ( Lg4) and it didnt Code.
So I guess not
You wont have any problems Running a Non EGR manifold. If you want to keep some of the Temp actuated Vaccum switches for Stuff like the Exhuast crossover and Smog pump and stuff, then you may have to consider Finding ports for them.
But if your dumping EGR, might as well Dump all that **** too )
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Feb 26, 2001 | 09:31 PM
Troy 85Z's Avatar
Car: 85 Z
Thats what I needed to know. I've been running without the smog pump for a couple of years but I was a little worried about tearing off the other emmisions hardware without having problems. My plan is to scrap all emmisions but retain the stock carb and distributer as long as its my daily driver. Thanks again
Old Feb 27, 2001 | 08:57 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
The only diagnostic your computer has related the EGR is for the EGR solenoid. As long as you leave that plugged in you'll be fine, it doens't matter if the valve is actually hooked up.
...ed
midge54
Jan 29, 2017 07:00 PM
mdtoren
Aug 23, 2015 12:52 PM
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
mdtoren
Aug 16, 2015 05:45 PM
