voltage
Car: '87 IROC-Z
Engine: L98 TPI/Possible LS1 swap
voltage
What is normal for a voltage reading? Usually it will read 13, but it will drop off to about 10 or so at times of idle.
87 Iroc-z Black out/Grey in. 350 tuned port. Auto. T-tops.
#3 Earnhardt is #1!!
87,
Normal voltage should be between 13.2 and 14.7 when the battery is fully charged and load is not beyond the output capability of the alternator at a given RPM. At idle, the accessory load can exceed the output capability and cause voltage drop. This can be normal and does not necessarily indicate a charging system problem.
Later,
Vader
"No matter how hard you try you can't stop us now..."
Adobe Acrobat Reader 4.0
Later,
Vader
Elephantismo
Feb 13, 2019 12:51 AM
