key and tumbler replacement
Old Mar 29, 2004 | 08:33 AM
86whitetransam's Avatar
Car: 1986 Trans Am
Transmission: 700r4 auto
ok my key and tumbler is all screwed up. im wondering if anyone has replaced them before? cause i have tried alot to get that dam thing out and cant figure it out.
thanks
Old Mar 29, 2004 | 11:05 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Once you're inside the door, you'll see how the lock comes out.
JamesC
Old Mar 29, 2004 | 01:32 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I'm moving this to general tech. There's nothing electrical in nature about replacing the tumblers.
Old Mar 29, 2004 | 06:57 PM
Car: 1986 Trans Am
wow your alot of help there jamesc
if you are not willing to help out then dont bother to post cause if it that easy as to coming out im guessing you havent did one before on these cars cause i have did many on other cars just cant figure out this one.
Old Mar 29, 2004 | 08:34 PM
JamesC's Avatar
I certainly didn't intend to be snide in my reply. My thought was that seeing would be expanatory. As I recall, the lock is held in place with a clip. Remove the clip and the lock rod, push the lock out, and you're good to go. Since you'll be inside the door, you might consider cleaning and relubing the power window and power locks to make them a bit quicker and more efficient. Also, check my link in the FAQ section for Window/Door Rattles for some ideas about tightening up that area. Good luck.
JamesC
Old Mar 29, 2004 | 08:39 PM
Car: 1986 Trans Am
james i think we are talking about something diff cause i want the acutally key and tumbler for the ignition key. sorry i thought u ment like open the car door and i should see how to get the tumbler outa the steering col.
Old Mar 29, 2004 | 09:11 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Going to have to do mine soon, haven't done one yet, but here's the jist of the deal:
1. Remove steering wheel.
2. Remove black dust cover from column.
3. Remove lock plate from column after removing lock ring from center.
4. Remove hazard switch.
5. You may want to lower the wheel to perform this operation, and if you do, remove both lower panels and unbolt the column from the dash frame.
5. Unscrew the turn signal switch and move it aside as far as you can. If you need to, unscrew the switch lever and remove it as well.
6. Place the lock cylinder in the run position (if possible), remove the warning switch, and then remove the screw that holds the actual lock in place. You may want to use a magnetic screwdriver so the screw don't fall down inside the column....
Old Mar 29, 2004 | 09:24 PM
Car: 1986 Trans Am
thanks i got the wheel off and that black dust cap off and thats about as far as i could get and i got two screws back in their off also. then it just kinda came to an end as to what to do.
thanks
Old Mar 29, 2004 | 09:33 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
When you get the ignition lock there should be step by step instructions on how it all goes in. Some you have to have the key turned in the plug, then there's a pin in the side of the lock you have to depress to get it all the way out. Most chevy's i have done were like this, but i never had to do a camaro yet.
Old Mar 29, 2004 | 09:38 PM
Engine: 2.7L V6
Axle/Gears: 4.41
If you got the wheel off, you may still be able to remove the lock plate. Just get some long bolts and two nuts to hold behind the framework for the puller so the bolts don't back out as you tighten the puller on the plate. You need a screwdriver or needle nose pliers to remove the center snap ring as well...
eightsixseven
Dec 16, 2024 01:50 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
