454 won't idle below 1400
Old Mar 29, 2004 | 10:35 PM
ehacker01's Avatar
it is a 454 bored 30 over, about 10:1, two 650 holleys, the cam is crane cams #139741
(http://www.cranecams.com/?show=brows...41&lvl=2&prt=5)
I have adjusted the air/fuel screws and the idle screws and nothing will get this thing to idle below 1400. it will idle at about 1200 if i give it a little gas to keep it going. Is this just how some larger cams idle?
Old Mar 30, 2004 | 02:14 AM
vampiroc's Avatar
Car: Z28
not really, that cam will be lopey at idle (around 700 rpm in gear) but it shouldn't die or anything. check your timing. high idle usually means too much advance. is your engine running hot?
Old Mar 30, 2004 | 06:05 PM
chev496's Avatar
Car: 90 RS
Engine: 8 holes
Transmission: Quickest, quicker, quick...
Axle/Gears: 10 bolt, 3.73
Well, i recently had that problem. First, make sure you have the idle adjustment screws set right. Also, make sure the floats are set rite. Then once that is in the right ballpark, adjust your timing. Have it around 12-14 intial if she has a big cam. Then, finish your carb. Also, check for vacumn leaks..
Old Mar 30, 2004 | 06:22 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Choke stuck closed maybe?
Old Mar 30, 2004 | 07:06 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
poss vac leak
MustangBeater20
Oct 29, 2022 09:20 PM
Logan Bryant
Aug 27, 2015 11:52 AM
Ozz1967
Aug 16, 2015 10:23 PM
Kaweh
Aug 9, 2015 02:54 PM
cRoe4
Aug 7, 2015 08:46 PM
