what spark plug heat range should i use?
Old Feb 27, 2001 | 10:14 PM
bad camaro RS's Avatar
what heat range would you reccomend? i will be running Nos what brand or type are good for nos thanks mods on sig
1992 camaro RS
195cc AFR heads with compition port work milled to 58cc "10.9 to 1 compression"
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
compucam 2032 with 1.65 full roller rockers
497-510 LIFT 214-220 duration
msd6AL
1 5/8 headman headers
2 `1/2 flowmaster exuast
k&n filters gutter air box gutted maf"no fins no screens"
3 pc under drive pulleys
no emissions no egr etc
custom ED Wright chip
eddelbroc intake base and runners ported plenum
accel 8.8mm wires
B&M mega shifter
gutted maf/airbox
hotchkis lower control arms
3" exhuast cutout
homemade cold air intake
2000 tci stall
700R4 with B&M shift kit edelbrock water pump
new best ET 13.5 @104.66
no times with new afr heads hoping for 12's on motor
Nos to be installed soon
Old Feb 27, 2001 | 10:20 PM
theformula's Avatar
Don't use anything but Ac delco regulars. no ac delco rapidfires, no champions, no NGK, no Bosch
I run a blower and I use AC Delco R43TS and they work great. No detonation. And they're only $9.76 for 8. Woo hoo
[This message has been edited by theformula (edited February 27, 2001).]
Old Feb 27, 2001 | 10:34 PM
Vader's Avatar
Spark plugs are a little like companions. (I was going to say "women", but the same could probably apply either way.) We all can agree on those that look good, but not necessarily on those we can live with.
I've always had good luck with Champions in ANY engine. AC/Delco platinums are good (the true platinums, not the "platinum-enhanced" ones). NGKs seem to be reliable but hard to find in the correct heat ranges and sizes for American engines. They seem to be a little better in the extra hot ranges. Bosch was O.K. once, but I have a feeling they have slipped a little in recent years (or the other manufacturers are catching up and passing them). Their true platinums are probably still O.K.
As for the "designer" plugs, forget them. You know the ones. They have multiple electrodes shaped like the Backstreet Boys' hairdos, or some ultra-high tech metallurgy that is "proprietary" so that they can't tell you what it really is, or those that have a fixed perimeter gap like a marine engine plug, or those with a fancy (read "expensive") colored insulator and anodized shell that makes them look better.
Between AC/Delco and Champion, there are probably seventy-eleven quadrillion error-free sparks every day in the world. And the last time I checked only Champion and Auburn were good enough to get an FAA approval for aircraft engines. Who is reliable now? I guess it doesn't matter in your car though. You can always get out and walk. I'm a little too lazy for that.
By the way, here's an AC/Delco under "stress":
(Actually, that isn't completely fair - this car really needed a tune-up about five years before I saw it. That should say something about AC/Delco reliability, too.)
Later,
Vader
"No matter how hard you try you can't stop us now..."
Adobe Acrobat Reader 4.0
[This message has been edited by Vader (edited February 27, 2001).]
Old Feb 27, 2001 | 10:39 PM
Vader's Avatar
Bad RS,
By the way, could you maybe condense your signature a little. Not necessarily remove anything, but try to run it in longer lines with spacers. I had to scroll down a whole page just to see the second post.
It's good to see all the informaton there to avoid unnecessary questions, but it does take a lot of vertical space.
Not a big thing, just a suggestion.
Later,
Vader
Cornholio7979
Sep 20, 2018 02:31 AM
evilstuie
Feb 28, 2016 03:33 PM
LittleFranks
Sep 17, 2015 12:22 PM
g.l.mos
Aug 22, 2015 12:02 AM
