ATTN turbo experts: How hard would this be??
Old Feb 27, 2001 | 07:38 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
How hard would it be to go to the junk yard, and pull a turbo off something like a V6 thunderbird, then adapt it to fit a carbed car? What about tpi? There are plenty of turbo-v6 t-birds in the junk yards around here, and most of them look like the turbo is in
good shape.
1983 Pontiac Firebird SE
LG4-Based Chevy 400
700R4 Tansmission
Modified 4 Barrel Q-Jet Carb
Accel Super Stock 8mm Wires
Edelbrock Pro-Flo Air Cleaner
3.23 Posi Rear
14X7" Cragar SS/T Wheels
Clarion 45X4 CD/AM/FM Head Unit
100WX2 Amp
2 Pioneer 12" Subs in Custom Box
Third Gen Performance
"A four cylinder is only half an engine"
Old Feb 27, 2001 | 09:51 PM
Enkil's Avatar
Try the poweradder board.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Feb 27, 2001 | 10:56 PM
Bort62's Avatar
Well, Im no Turbo Expert, But I consider Myself a Turbo-Informed Individual.
The Idea is Simple. PLumb the Turbo Into the Exhuast and Push air into the carb.
The application Is alot harder ( Isnt that always the case ? )
What are you looking at ?
First off, With an engine as big as the 350, You will be hard pressed to Find a Single Turbo With enough Huff To Feed it.
So the Usual answer is Twin Turbos.
Two To3's May Be Decent, Two T04's Would be better, But thats a Whole Nother arguement.
What You would need to Do is Fab a exhuast manifold That Provides for the Turbo Mounting. then You need to decide If Your Running Draw through or Blow through. I would think Blow through would be the best answer On OUr cars.
Anyhow Once You have the exhuast routed Such that the Turbo's Spin ( not quite as easy as it sounds, btw ) Then You gotta Pump that air through the Carb. Not all that hard, Just Fab Up some Ducting ( haha, not that simple ) and Your blowing.
Simple as that ? no.
You need to setup a wastegate, To keep from Boosting Your Motor Into fragments. You also need to Setup a Boost Actuated Fuel pressure switch, Increase pressure with boost ( if you plan to run any decent amount, anyway )
Also Keep In Mind you have to retard timing as boost rises.
PLumb Some Oiling lines for the Turbos to keep them Spinning.
If Your going to go through all that trouble, Your Going to Want Intercoolers, More plumbing. Oh yeah, No intercooler For Draw thru, Unless yOU like creating Pipes Full Of Atomized, Cool, dense Gasoline/air Mixture Waiting For A backfire...
Lets not Forget that if your going to Go to all this trouble, Your gonna want to Run some Signifigant boost. So If you want to keep it all attaced, Forged pistons, Rods, crank, $$$
All In all its not all that hard, Im sure I Have Forgotten something, but its mostly there. The problem is actually Doing it.
But it has been Done, and Will Continue to get easier )
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Feb 28, 2001 | 05:58 AM
Tas's Avatar
Tas
my friend had a diesel 4cyl rabbit. he got a turbo off a mercedes and hooked it up. then he got propane and plumbed it into the intake. propane is like Nos on diesel. and he had the BBQ tank in the back. lol. he blew it of course.
-Tas
'89 Formula WS-6
[soon to be Torch Red with black hood and headlights =) ]
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Super GRK_Taz World
EFI & Intake Options
AOL IM: superGRtaz | ICQ 82881207
Old Feb 28, 2001 | 06:04 PM
The ODB's Avatar
I have a friend named Mike who is a turbo expert and has done what you are talking about with junkyard turbos several times & created several ten second cars.
here's his current website.
http://www.geocities.com/toohighpsi/index.htm
Old Feb 28, 2001 | 08:59 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Anyone know how big the turbo on a 7.3L Powerstroke Diesel is?
customblackbird
Oct 1, 2015 04:30 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
Breazlan
Sep 25, 2015 11:20 AM
Randomtask2
Sep 7, 2015 05:06 PM
tgp1990
Sep 4, 2015 06:24 AM
