Will MyTires Vibrate?
Old Feb 28, 2001 | 06:32 PM
mcconahay37's Avatar
I have about 7000 miles on my tires. I'm tired of looking at the white letters on the side and want to flip the tires over then rebalance them. Can I do this, or will my tires vibrate bad because of wear patterns?
82 Camaro:
350, Erson cam, ported heads, Crane Hi-6 ignition, Accel supercoil, Comp Cams 1.6:1 rocker arms, Turbo 350 tranny with 2500 stall.
Old Feb 28, 2001 | 09:15 PM
Vader's Avatar
Mac,
As long as the tires aren't a directional tread and carcass (or if they are, are used in the correct direction) it shouldn't matter. If you ae concered about the direction, remount and balance the tires, then install them on the opposite side of the car where the rotation direction will be the same (the same as you would have to do with directional tires).
Later,
Vader
"No matter how hard you try you can't stop us now..."
Adobe Acrobat Reader 4.0
Old Mar 1, 2001 | 12:47 AM
Thanks. That's what I figured, but wanted to make sure before I messed with it. No reason to do the extra work of flipping the tires if I just have to redo it later. They're bfg radial t/as. Not the best tires, but they work.
82 Camaro:
69GTOby
Apr 18, 2016 02:34 PM
sac92transam
Oct 7, 2015 02:31 PM
roysatikas
Sep 22, 2015 08:15 PM
BWilcox
Sep 20, 2015 12:19 PM
InfinityShade
Sep 18, 2015 08:32 PM
