Why does it not idle sometimes??
Old Mar 1, 2001 | 12:29 AM
ADMZ24's Avatar
Car: 1991 Trans Am
My friends 88 Formula 305 TPI is experiencing an intermittent idle problem. THe car will run great for a while, and then all of a sudden, when you slow down to stop. It wont idle, just drop and die. All new plugs, wires, cap, and rotor. The timing is correct. The TPS is fine, it is correctly adjusted, could it be IAC?? I will try cleaning it first, but if it still doesnt idle, then how can i tell if the IAC is bad??? Or could this be fuel related? Possible fuel filter..injector problem..fuel related at all??? Any suggestions are welcome, it is dangerous when driving a car that dies without warning!!
1991 WS6 Trans Am
Dark Green Metallic
Camel interior
305 TPI
TH 700-R4, Auto
T-Tops, PW, PL, PM
Keyless entry, alarm
Flowmaster Muffler
Monza Dual Tips
K&N Filter
Old Mar 1, 2001 | 01:36 AM
burnoutrpm's Avatar
try the fuel filter always start with the corect or cheapest thing first!!!
89 firebird formula
356 9:1 compression
comp cams xe262 cam
performer rpm intake
#1405 edlebrock 600
882 casting 202/160 valves
msd 6al
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b&m trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
