Help, need to decide which mod will yield the most improvement
Old Mar 1, 2001 | 08:47 AM
Brandog87GTA's Avatar
I am getting to the point where I cant mod very much anymore. The only things I can do now are roller rockers, gears,stall converter, or hook up my nitrous(all I need is the plate). For the money what would yield the most impact? I wanna lean away from nos because I dont wanna blow my new motor that I just built.
Bright red 87 GTA with I have stock 3.27 gears,stock converter,B&M shift kit, TRW forged 9.75:1 pistons,comp cams pushrods, edelbrock valvesprings, 462 camel hump heads with 2.02in/1.60ex redrilled for angled plugs, 3 angle valve job, ported and polished, performer RPM intake, mallory fp regulator, edelbrock 750 CFM carb, hei ignition(new) with 10,000 volt coil,No cat, flowmaster 2 chamber mufflers, hedman full length headers, edelbrock cam with 488/501
Old Mar 1, 2001 | 09:16 AM
Steve89GTA's Avatar
Have you run the quarter mile yet?
What kinda times is your setup giving you?
89 GTA G92
305 TPI WC 5spd w/3.45
Accel Cap & 8mm Taylor's
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch TB Bypass - Steel Rad
Cat back 3" Exhaust w/Terminator Muff.
HiGh FlOw Dynomax Cat
Spohn LCA's - KYB GR-2's
Autometer Vac+Oil Temp
Old Mar 1, 2001 | 09:23 AM
Havent ran it yet, but will soon. Trying to get to do a few more mods before I run it.
Old Mar 1, 2001 | 09:27 AM
JETHROIROC's Avatar
Definitely go with a Vigilante converter if the nitrous makes you nervous right now. It's probably the most noticeable mod for the money in your list of possibilities.
Old Mar 1, 2001 | 09:44 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You might want to consider some suspension mods... most likely you're already traction-limited, any further upgrades to the drivetrain are not fully useable until you can hook up more power to the pavement.
ICON Motorsports
Old Mar 1, 2001 | 11:08 AM
Bort62's Avatar
agreed RB.
You need to look at the whole picture.
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
J-money
Jan 4, 2019 09:45 AM
Fronzizzle
Feb 9, 2017 09:31 AM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
topteam54
Oct 6, 2015 12:21 AM
Springster
Sep 13, 2015 01:38 PM
