Problems with starting my car, key won't turn?
Old Feb 28, 2001 | 05:35 PM
Camaro_84's Avatar
I can't seem to turn the key when I put it into my ignition. I own an 86 Iroc. My friend has an 88 base model and had the same problem, so all he did was spray some lube into it and he hasn't had anymore problems. I borrowed his lube and tried it, but I can't seem to get it to work. I haven't seen any improvement.
Old Feb 28, 2001 | 06:20 PM
ede's Avatar
ede
try another key, if that doesn't work i'd guess your cylinder that the key goes in needs replaced.
ICON Motorsports
1st & 3rd
Old Mar 1, 2001 | 09:29 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Does this happen all the time, or just now? You know how after you pull the key, the steering wheel locks against turning? Well maybe the wheel was "forced" to one side, and preventing the key from turning. Solution? Turn the steering wheel the way it can go, and put the key in, and turn the key.
Make sure to use a graphite key-lube, not something like WD-40. The WD-40 will actually clean all the graphite off the tumblers in the lock, and screw up your lock.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Mar 1, 2001 | 12:44 PM
Skip Howard
Guest
Posts: n/a
Probably a stupid idea but make sure your not in drive too. My key won't turm if I'm not in park.
85T/A 305/QJ work in progress.
Old Mar 1, 2001 | 02:22 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
i had a problem similiar to this, where the key would go, turn to accesory position, but no furthur. It turned out to be the key cylinder thingee was shot. 180 bucks later i was able to start my car
Old Mar 1, 2001 | 02:25 PM
Ace_Murdock's Avatar
Car: 1985 Z-28
Engine: a big one
Transmission: 4 spd auto soon to be a 6 speed
I am actually having this proble right now too. I have found that the ignition switch was faulty. I could kinda turn the car on, but it took both of my hands to turn the key so I could turn it off.
So check your ignition switch, I found this out because the little rod going to it was bending pretty good.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
BrianI
Aug 9, 2015 11:52 AM
86Base
Aug 8, 2015 01:34 PM
Sherpajames
Aug 7, 2015 06:56 PM
