one fan workes the other doesn't HELP!!
Old Mar 1, 2001 | 05:05 PM
millertime's Avatar
Hey! I was under the hood the other day (been spending way to much time there the past few weeks) when I seen only one fan working. I went direct to the fan with a hot wire and it worked. checked the relay on the passenger side had juice comming in but not out. Jumped two wires there and the fan worked. replaced the relay and the fan still does not work. Is there any other relay or something else to check?? HELP!!!
Old Mar 1, 2001 | 05:10 PM
Mo's Avatar
Mo
One of the fans is not supposed to come on until the engine gets really hot, I think its the pass. side, but I could be wrong.
90 IROC 5.7l (L98)
ram air, K&Ns, air foil,Flows
LIKE A ROC
Old Mar 1, 2001 | 07:09 PM
JETHROIROC's Avatar
Right. The passenger side fan on my '90 IROC didn't come on until about 250*F, so I replaced the sending unit on the passenger side of the engine block with a 220*F one. It looks like a coolant temperature sensor, and well, actually it is, just not the one the ECM uses for fuel metering (that one's under the throttle body). Much better now.
Old Mar 1, 2001 | 07:42 PM
Blue5.71LE's Avatar
I just went through the same thing on my 91' but it was the drivers side that is the lag fan. Frustrating, yet funny.
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
TheExaminer
Aug 26, 2015 04:59 PM
Leggman1
Aug 6, 2015 04:15 AM
