Car missing..quick question
Old Apr 1, 2004 | 07:24 PM
kakarot's Avatar
Car: 1986 IROC , 1987 IROC (Kid's car)
Engine: 305 4bbl, 305 TPI
Transmission: T-5, 700R4
Got an 87 IROC with a 305 TPI. Car misses at idle and throughout RPM range. At highway speed it lugs real bad in overdive while you are accelerating. I've changed cap, rotor, wires, plugs..etc. The dead cylinder is #2. All cylinders have good pressure, fuel and spark. I was told by a local garage that it was definaltely a worn valve guide causing the problem. The plug carbon fouls quickly, but there is no oil on it. Anyone else have this problem and found a valve guide was causing it?
Old Apr 2, 2004 | 12:01 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Car missing..quick question
It could be as simple as a clogging fuel filter or a dying fuel pump or as sserious as you described. I would check the fuel system. GM fuel systems are not the most reliable thing out there.
Old Apr 2, 2004 | 11:07 AM
kakarot's Avatar
The pump and filter are good, the fuel pressure tests fine at the fuel rail and the injector is working properly, still has a dead cylinder.
Old Apr 2, 2004 | 02:52 PM
onfire's Avatar
Car: 88 Formula 350
Engine: 5----->.7 or so they say
Transmission: seven hundred with a remainder of 4
Axle/Gears: 9 bolt 3.27
It would be a good idea to run a compression check on your #2 and on all your cylinders just to verify what is going on. I would check your rocker arms and see if they are on tight or if there is chatter/dead lifter. When the lifter (hydrolic roller for my application) went bad on my bird it made a squeeking noise which indicated it was not getting lubricated.
Another place to check would be your air sensor. THis is located on your exhaust driver's side and lookes like a spark plug thats screwed into afitting. I have experienced this go bad on my bird and it helped significantly once I replaced it please check it before you buy a new one. Have your mechanic test your emitions to see if the car is running lean or rich. These extremes would indicate a faulty air sensor.
Old Apr 2, 2004 | 03:39 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
If you are sure it's only one cylinder, look for collapsed lifter, bad rings (do a cylinder pressure test ) bent pushrod, head gasket or as mentioined bad valve guide.
Old Apr 2, 2004 | 03:51 PM
kakarot's Avatar
All cylinders tested ok for pressure so I'm leaning towards the lifter/valve spring/valve guide idea. Thanks for all of your input on this!..it's people willing to help other people that continue to make this a great board and a great resource.
MustangBeater20
Oct 29, 2022 09:20 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
jharrison5
Aug 19, 2015 05:53 PM
Exxon Limited
Aug 9, 2015 08:13 PM
