airfoil???????
Old Feb 28, 2001 | 10:01 PM
Blue5.71LE's Avatar
airfoil???????
Hey guys i see a few of yous have airfoils. is it worth the money?I saw one for about 60$what kind of difference does it make?
Old Feb 28, 2001 | 10:06 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Get an SLP. They run about 29.99
Old Feb 28, 2001 | 10:39 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
They do make difference, even if some say they don't.
Looking For:
87 IROC-Z 350 TPI
84 TRANS AM 305 H.O.
Old Feb 28, 2001 | 11:53 PM
JETHROIROC's Avatar
I got the SLP the other day on sale, probably install it tomorrow and I'll let you know if it was worth it. I'm not expecting anything noticeable, but every little bit adds up.
Old Mar 1, 2001 | 12:39 PM
Kevin Irving's Avatar
Car: 1985 Trans Am
I didn't really notice a difference, and I've used both the SLP and the JET (which I'm using now), but every little bit helps. Suppose I should be able to feel a SOTP diff when I finish my custom cold air kit to free up the intake.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, TB Coolant Bypass, Ported Plenum, Modified MAF, Syclone Fuel Pump, JET Airfoil
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Old Mar 1, 2001 | 04:10 PM
Mo's Avatar
Mo
I didn't notice any SOTP difference, but someone around here did a flow comparison and it increased the air flow, so it does do something whether you feel it or not.
90 IROC 5.7l (L98)
ram air, K&Ns, air foil,Flows
LIKE A ROC
Old Mar 1, 2001 | 04:21 PM
Dan87IROC-Z's Avatar
Like was said above, every little bit helps. I can't say I felt a difference with my Jet airfoil, but I know that it had to help some.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
Old Mar 1, 2001 | 07:46 PM
Blue5.71LE's Avatar
thanks for the info guy, one other thing was that 29.99 CAN or US?
Old Mar 1, 2001 | 10:18 PM
JETHROIROC's Avatar
U.S.
Old Mar 2, 2001 | 03:24 PM
Eric's Avatar
Car: 87 GTA
Be aware that ordering from SLP in the States will cost you big bucks for shipping to Canada. I ordered the airfoil from SLP... paid $29.99 USD, $7.95 USD for shipping, all charged to Visa - that works out to about $60 CAN. Great. However, when the part came to my door, it was shipped via UPS courier, and I had to pay an ADDITIONAL $40 CAN brokerage fee!!!!! SO that $29.99USD part cost me $100 CAN. That is WAY too much - buy the part locally for $60 if you say you can find it hree in Canada.
My $.02
Eric
87 GTA 350 TPI, 700R4,
K & N, Accel cap/rotor/wires, SLP airfoil, ported plenum
kairles
Oct 26, 2015 09:13 PM
vortech305
Aftermarket Product Review
Dec 5, 2001 02:01 PM
J's86ROC
16
Nov 14, 2001 11:42 AM
Camaro92
Mar 13, 2001 02:45 PM
hookin88formula
Oct 16, 2000 11:25 PM
