fuel pump switch not clicking
Old Apr 3, 2004 | 05:50 PM
RED82TA5.7L's Avatar
Car: 96 Formula/82 T/A
Engine: LT1/350 TPI
Transmission: T56/TH350
this is on the 82.....
replaced pump relay.. and also checked power to the fuel pump fuse and also power to the relay, everything there checks out ok.. car will start then die instantly cause i have an aftermarket pump up front to boost pressure(i know but i didnt wanna take the tank out ) but i dont hear the clicking i normally hear.. and if i take the fuel hose off at filter up front(before the aftermarket pump) there is 0 fuel coming out with key on.
what else should i check before takin the tank out and replacing pump(if thats what it is)
ive also heard theres a fuel pump switch.. where is that at?
thanks
feel free to move this.. didnt know which one to post it lol :lala:
Old Apr 3, 2004 | 09:25 PM
Engine: LT1/350 TPI
noone knows anything else to test?
Old Apr 6, 2004 | 06:39 PM
Engine: LT1/350 TPI
Old Apr 6, 2004 | 07:58 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The switch that I believe they are talking about is the oil pressure switch, it is a back-up to the fuel pump relay. It is located near the oil filter on the drivers side.
Old Apr 6, 2004 | 08:35 PM
Engine: LT1/350 TPI
can that not working cause the fuel pump not to work? cause i got oil pressure if i do get it running(will run for few seconds)
Old Apr 6, 2004 | 08:50 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You can check the fuel pump in the tank by applying 12 volts DC to pin "G" of the ALDL and grounding it at pin "A" of the ALDL. Have someone stand by the fuel tank to listen for the pump, although you should hear it in the car.
Old Apr 6, 2004 | 08:59 PM
Engine: LT1/350 TPI
thanks that helps alot should key be on or off?
Old Apr 7, 2004 | 06:14 PM
dailydriver's Avatar
i have an '89 iroc, HO305, 700r, tpi. can i use this same diagram to test my fuel pump? The car will crank and then die immediately.
Old Apr 7, 2004 | 07:13 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yep.
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
89GTAOz
May 16, 2020 09:31 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
