tranny crossmember bolts broke!
Old Apr 3, 2004 | 07:04 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
whats the best way to repair bolts that snapped off the crossmember? drill and re-tap? what would you guys recommend?
Old Apr 3, 2004 | 08:57 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Do you mean to say they broke off or stripped in the frame rails?
If so you'll need to cut an access hole in the side of th frame rail near where the crossmember nut is located.
Cut a "U" shaped door and fold the sheet metal back.
then you can cut out the nut with a cutting torch and then weld in a new stainless nut. use a stainless bolt too.
Old Apr 4, 2004 | 09:52 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
no they snapped off and the bolts are still in there
Old Apr 4, 2004 | 03:02 PM
F-BIRD'88's Avatar
Follow the post above. Blow the old broken off bolt and nut out with a cutting torch, Weld in new nuts and button it back up. had to do this to mine.
Don't use impact tools on these bolts.
Old Apr 4, 2004 | 03:10 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
if the nuts arnt stripped themselves and you just have broken off bolts stuck in the hole i'd try some easy outs first, then if the threads in the nuts are still good just replace the bolts, if all is lost follow the above post.
New2Chevy
Sep 28, 2015 12:35 AM
billybob6110
Sep 23, 2015 01:30 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
