Tip-in troubles -
Old Apr 3, 2004 | 08:19 PM
nicksL98's Avatar
Tip-in troubles -
again.. 90 Iroc LB9/auto. stock. It seems to be working fairly well now as i get more miles and run time behind it. Looking at scantool,car is at operating temp, when throttle is held at very light application say 1%-5% it likes to stumble and/or die out fairly often. If you have the throttle anyhting over 6% its mostly fine, no bog or stumbles. Dies moreso when you come to a complete stop, idle then attempt to move slow again, all other areas above 6% throttle are okay. TPS is smooth action, i can read every .02v from .58 - 4.20v IAC was set previously, car idles smooth at 625-650 in gear. adjsuted timing 10 deg btdc, up from 4 deg. any suggestions?
thanks,
Nick
Old Apr 5, 2004 | 09:54 PM
nicksL98's Avatar
Vader - its my last major headache i swear!! I'll even buy you lunch when i get back down there!
mrbird
Oct 20, 2015 03:43 AM
Lmancha96
Sep 25, 2015 08:11 PM
HikoriYami
Sep 21, 2015 07:11 PM
BWilcox
Sep 20, 2015 12:19 PM
eduardosac
Sep 16, 2015 02:18 PM
