Engine shutting off at red lights
Old Mar 2, 2001 | 02:04 PM
jody92RS's Avatar
I realize that this question is not for my "thirdgen" car, but I'm desperate! In addition to my camaro, I also have a 95' Grand Prix 3.1 liter engine, automatic. It has started occasionally stalling while in a stopped position. Once I give it gas, it's fine. I can stop the stalling process by giving it gas. Please Help!!! Any ideas will be greatly appreciated.
1992 25Th Anniversary Camaro
305 TBI
5 Speed
Old Mar 2, 2001 | 02:40 PM
theformula's Avatar
Though it could be any number of things, it sounds like a bad TPS sensor
Old Mar 2, 2001 | 03:27 PM
jody92RS's Avatar
Though it could be the TPS sensor, it's not throwing any codes. No SES light is coming on at all.
305 TBI
5 Speed
Old Mar 2, 2001 | 06:21 PM
Mo's Avatar
Mo
I don't know much about GPs, but bad IAC maybe, it didn't throw a code on the ROC.
90 IROC 5.7l (L98)
ram air, K&Ns, air foil,Flows
LIKE A ROC
Old Mar 2, 2001 | 07:53 PM
jody92RS's Avatar
What exactly is an iac and where is it located?
Jody
305 TBI
5 Speed
Old Mar 2, 2001 | 08:05 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
he is right, it could be any number of things. a dirty fuel filter will do the same thing, or a weak fuel pump. yes, a TPS would do it, but i dont know if the IAC would. just my .02
Wide Open Till You See God...Then Brake
Old Mar 3, 2001 | 09:12 PM
mikeage2's Avatar
IVE FIXED ALOT OF PONTIACS,WE SELL ALOT OF GRAND PRIXES AND GRAND AMS.
THE IAC IS THE IDLE AIR CONTROL VALVE.IT IS BOLTED ONTO THE THROTTLE BODY BY A COUPLE OF TORX SCREWS.PULL IT OUT,AND CLEAN THE PASSAGE+THE IAC ALL TO HELL WITH SOME CARB+CHOKE CLEANER.IT MIGHT BE IN YOUR BEST INTEREST(ESPECIALY IF THIS CAR HAS SOME MILES ON IT)TO COMPLETELY PULL THE THROTTLE BODY OFF AND CLEAN THE BACKSIDE OF THE THROTTLE PLATE TOO AT THE SAME TIME
LATER!
MIKE
86 camaro:was a v6 car,now its going to be a v-8 5.7l!!
350:cylinders bored .040 over.a little over 9:1 compression(getting a blower some day when im rich lol)line bored.deck is milled a little(was pitted)
trw forged pistons with summit stage 2 polished rods with arp bolts.
194? intake valves(not 2.02( ),pocket ported,gasket matched,and polished ports,old vette intake with new zinc 650 holley
ase certified for a few years,learned alot though
working on freakin NEONS ,cirruses,tauruses,cobras(well` at least they look nice lol)and intrepids all day makes me drink too much
good job security though
im always on the lookout for cheapv-8 t-5,s
and t-56 setups.they must be cheap.i dont care of they need rebuild,as long as they arent totally blown
jaridjohn
Jul 8, 2024 03:49 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
