speedo cable go bad?
Old Apr 6, 2004 | 09:02 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
I have an 83 Z28 (100K) with a mechanical Speedo w/ cruise. It has some bounce when you get above 50 mph. I have lubed both cables (upper and lower) with no real change. Is it possible I need new cables? Do the mechanical Speedos do this over time?
Any thoughts would be welcome.
thanks,
phil
Old Apr 6, 2004 | 11:05 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like you have cruise....
Does the cruise regulator spin freely with the cables removed? Those often cause that.
Old Apr 6, 2004 | 12:10 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Yes i do. I am going to look at it again, but several years ago the cruise stopped working and seized up, so i removed the friction disc inside. I think that now there is just 2 gears turning freely inside.
phil
GTAman
Jul 3, 2024 07:29 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
andy74
Sep 3, 2015 08:41 AM
