Oil Pressure Sending Unit...Which One?....Hard to replace?
Old Apr 6, 2004 | 08:34 PM
TPI86TA's Avatar
Car: 88 GTA
I need to replace my oil pressure sending unit on my GTA. Ive only seen them in 15, 30, and 50 PSI. Now i dont know which one to buy and my oil pressure gauge has a max of 60 PSI on it. I just wanna make sure i buy the right one.Does anyone maybe know a part number or where i can get the right one, how much it might cost, and which PSI i want. Also, is it hard to replace?
My car is an 88 Pontiac GTA w/ a 5.7 lt 350 TPI....Thanks,Al in NJ
Old Apr 7, 2004 | 01:25 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Just go to the parts counter at any autoparts store and tell them what kind of car you have and that you want an oil pressure sending unit. If its in stock, theyll hand you the right one.
Old Apr 7, 2004 | 09:40 PM
TPI86TA's Avatar
Car: 88 GTA
ok cool thanks,so is it hard to replace and where on my car is it located.Ive never done this before...Thanks
Old Apr 7, 2004 | 10:05 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
It should be behind the intake manifold behind the rear china wall off to the drivers side. if it isnt there its in the side of the block above the oil filter, its very easy to replace.
Old Apr 7, 2004 | 11:25 PM
Car: 88 Camaro SC
Engine: SFI'd 350
The one above the oil filter is teh oil pressure switch. AFAIK, it serves only as a backup power switch for the fuel pump in the EFI cars.
89GTAOz
May 16, 2020 09:31 AM
db057
Aug 22, 2015 08:17 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
