Will a bad computer prevent running?
Old Mar 4, 2001 | 10:36 PM
Josh 91RS's Avatar
Right now my fuel pump is shot, and my ecm may be also. I am swapping in a new motor in about a month, but i want to get it running right now so i have transportation for that month, and can get it smogged before i make the switch to carbeurated. If the computer is bad will the car still run at all? I took it to a mechanic to make sure my diagnostic was correct, and he told me that the computer may be bad, that the signal to the fuel pump relay is intermittent...sometimes it works, sometimes it doesnt. If the computer is bad, but the car still runs, will i be able to pass emissions, or with a bad computer will that cause problems?Thanks guys.
Old Mar 5, 2001 | 01:19 AM
Dan87IROC-Z's Avatar
When my ECM went out last year the car still ran. It ran poorly and lacked power, but it ran and it was driveable.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
eightsixseven
Dec 16, 2024 01:50 PM
theshackle
Mar 5, 2017 06:37 PM
bamaboy0323
Aug 15, 2015 07:20 AM
Bradsaundry
Aug 12, 2015 12:34 AM
Jake_92RS
Aug 11, 2015 10:39 AM
