very hard to start
Old Mar 3, 2001 | 08:43 PM
5.0GTA's Avatar
very hard to start
ok, the past week i've noticed my idle getting rougher and rougher..to the point where my hood would vibrate. Then i went to the 1/4 strip today and after the 1st pass i turned the car off, let it sit, and when i went back to start it, the car would start, but the idle would be VERY VERY rough and go back and forth between 300-800 rpm and when i pressed the gas pedal the engine wouldnt rev. I would have to start it about 7 times before it would finally keep a steady idle. Also, i was disappointed with 15.8 @ 86.7 mph timeslips..this coming from a slightly modded 305 TPI...correct me if i'm wrong, but isnt 15.8 WORSE than stock? Some guy told me that my computer was putting out codes 34 and 40 i think, which were MAF sensor and the engine was running lean. This leads me to suspect the fuel filter is clogged and not letting fuel get to the engine, which would explain running lean AND the horrible timeslips. Anyone got any comments or suggestions?? I was really expecting low 15's
1988 Pontiac GTA 5.0 TPI
-K&N Filter
-Hypertech Air Foil
-Hypertech Perf. Chip
-2.5in Flowmaster Muffler
-Catco Hi-flow Cat
Kills
94 Probe GT, 95 Mustang GT, 96 Impala SS, 85 Thunderbird 5.0, 95 Accord V6, 98 Integra VTEC, 70 Chevelle Malibu, CRX w/ Turbo and Intercooler (have it on tape to prove it)
Old Mar 3, 2001 | 08:49 PM
mikeage2's Avatar
yes a fuel filter might set a lean condition code,but not a maf code.those are pretty notorious for going bad
Old Mar 3, 2001 | 10:27 PM
bullfrawg's Avatar
replace your sensor
1985 TransAm BLK/GLD Stock
1985 TransAm BLK/BLK
305HO (soon as it is put in) 5-speed, 3.27 posi, WS6, power everthing.
http://www.geocities.com/bullfrawgs
Old Mar 3, 2001 | 10:34 PM
Vader's Avatar
GTA,
Unless you implicitly trust "some guy", I'd advise scanning for error codes yourself. Whatever you find might help answer the idle problems. It's gotta be worth five minutes to get the error codes first hand, instead of from "some guy".
Later,
Vader
"No matter how hard you try you can't stop us now..."
Adobe Acrobat Reader 4.0
Old Mar 4, 2001 | 01:21 PM
5.0GTA's Avatar
well the 'some guy' that i was referring too was somebody that i had seen at the local Car Shows during the summer and I've also seen his car on Fbody.com. So I trust that he wouldnt screw me over since he had a '87 T/A with a 305/5-speed that knocked down a 13.9, so i think he would know what he was doing. and i dont have a code scanner anyways
-K&N Filter
-Hypertech Air Foil
-Catco Hi-flow Cat
Kills
[This message has been edited by 5.0GTA (edited March 04, 2001).]
Old Mar 5, 2001 | 11:47 AM
ArnoldBraker's Avatar
You don't need a code scanner to scan for codes. All you have to do is use a paper clip to jump the first two holes on the top of(a & B) the ALDL connecter under the drivers dash. Then turn the key to the "on" postion but not running. The SES light will flash 12, then any error codes you have. Hope that helps. ~Arnold
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
cstrobel65
Aug 15, 2015 10:19 AM
92camaroJoe
Aug 13, 2015 06:07 AM
