Need help with fixing code 45(oxygen sensor rich)
Old Mar 5, 2001 | 05:41 PM
vadrad's Avatar
Hey guys the help here is great better then any mechanic shop, anyways I finally found out with all the help from here that my camaro has code 45 oxygen sensor rich how do I fix this problem, thankyou very much
Old Mar 5, 2001 | 06:23 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The first thing you need to do is figure out whether the car is in fact running rich, or the O2 sensor is bad.
I'd suggest simply replacing it as a quick cheap stab at it. They should be replaced as part of a "major" tuneup anyway; if you haven't done it in the last 50,000 miles or so, you should anyway.
That may fix the problem or it may not. Try it and get back with the results.
ICON Motorsports
Old Mar 5, 2001 | 06:55 PM
82RECAROTA's Avatar
dyeager535
Aug 28, 2015 08:10 AM
Bert87
Aug 23, 2015 03:50 PM
beast94
Aug 20, 2015 06:44 AM
squiggy2
Aug 9, 2015 09:30 PM
