lots of problems with my 89 fbird
Old Apr 9, 2004 | 12:54 AM
VaporuS's Avatar
Car: 1989 Firebird
Transmission: not sure
I recently acquired a 1989 firebird for my 16th birthday. The car was free and all I was told it needed was an alternator. So...I bought the alternator and my uncle and I put it in. Well then I learned it must have a timing problem or something else becaus I can start it up and it Idels fine until I put it in gear. I have replaced the plugs and wires and there was no change.
Another problem is something keeps killin the battery. While I was checking the fuses I noticed a tumbler thing with a key in it. I have no clue what it is but if I d/c it the car won't start. If anyone knows what it is I would really like to know.(the key doesn't turn all the way to a start mode)
Old Apr 9, 2004 | 09:12 AM
Vader's Avatar
VaporouS,
Welcome Aboard!
At least you didn't pay too much for the car. You seem to be describing some sort of aftermarket alarm or cut-out switch, which may be causing some of your charging problems.
As for the problem with idle, you'll need to provide a bit more information. What engine and fuel system do you have?
Brandon, eh? I'm originally from Oshkosh.
Old Apr 12, 2004 | 02:20 PM
VaporuS's Avatar
Car: 1989 Firebird
More info
My car has a 305 with the TPI system.
jhawkeye
May 25, 2022 06:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
g.l.mos
Aug 22, 2015 12:02 AM
okfoz
Aug 21, 2015 07:38 AM
Fronzizzle
Aug 17, 2015 02:52 PM
