Removing piston from rod
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
What is an easy way of removing the piston and pin from the rod. Can i just heat up the rod with a torch and try and press it through. I don't have a press here, but i could go to the machine shop at school(UofI) and do it. Or should i just take it to a shop and have them do it. THe reason i ask is because i bought a 350 shortblock from a friend. It had a broken piston in it and he wants it for a trophy piece. I don't really care about the rods because i will probably use aftermarket capscrew rods for my 383.
thanks
thanks
gixxer92
Sep 1, 2015 04:32 PM
